Originally posted by stefcio007
View Post
MK3 Random Thread
The motor also had a bunch of rooted valves. Hope it's a different one in thereOriginally posted by Speed View PostThat's awesome. That means it's been owned by at least 4 forum members including myself. She really does deserve to be rebuilt. Currently has 5 studs and vr6 brakes, no interior but filled with lots of parts.
They are probably EURO ones, which is the same as our models.Originally posted by doridori View Postwant to get a set of smoked front indicator and reflectors, any recommendations on which to get?
Have my eye on a set of these but they are from Latvia and seller says that they will require modification for US models.
Any idea about australian ones?
link: VW Golf MK3 Bumper Reflectors Turn Signals SET | eBay
I think there is only US spec and EURO spec for the MK3s.Past - '95 VW Golf MK3 VR6
1.8 is gone. Has a vr6Originally posted by HaydEn View PostThe motor also had a bunch of rooted valves. Hope it's a different one in there
Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Originally Posted by JoeVR
I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
Can a tablet be hooked up to the ecu for guages?Originally posted by browntown42 View PostAnyone done any gauge installs? What would be the most useful and what would be easiest ones? CheersMk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Android tablet + bluetooth ECU reader, easy.Originally posted by Speed View PostCan a tablet be hooked up to the ecu for guages?
Only works on the late models though as the electronics support the current standard.Past - '95 VW Golf MK3 VR6
And how do you know this when the motor was bought separately and only went in the car last Saturday?Originally posted by HaydEn View PostThe vr motor didMk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Turns out last time they replaced the wrong switch. I guess that's what happens when the crack pipe cracks and thermostat housing crumbles at the same time. (happened last year)
Now both switches are new so not expecting any problems from there anymore.
Thanks mate. Did Hayden drive his beastie down to you or you end up freighting?Originally posted by Red9N3gti View PostThe first vr motor did. I ended up selling the head to hayden and the block ended up being scrapped along with the donor shell. The engine that is in there currently is differentMk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Have posted this in the wanted section but I know that not everyone goes looking in there, so thought I would try here as well.
I badly need a pair of rear caliper sliding pins and boots, I f#@&*d a pair of mine trying to free them from the carrier (seized), bought a decent set of used calipers thinking that the carriers and pins would be included, but they weren't. Seller sent me a carrier and pins but thy aren't correct, so still in need.
HEEEEEELLLLLLLPPPPPPPP
here's the pics of what I need
they are about 70mm long and about 8.4 mm in diameter, one looks like it has 3 small flat sections on the pin and the other steps down in diameter 3 times
Boot has Girling 32320498 on it
This is my caliper in case you need to see that as well, I don't need a caliper, but will take one if I have to so I can get what I need
Calling NSW Mid North Coast VW Enthusiasts - Click Below
Mid North Coast Dub Club
Will send you a pm
