MK3 Random Thread
How do I disconnect the brake wear indicator? I've joined the wires together before the plugs and the light is still on.
Can I just remove the bulb from the instrument cluster?
When the rear brakes go back in and the system is bleeded I will finally be done and ready to rego and hand the keys to my mother in law.
Sent from my GT-I9506 using TapatalkMk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Originally Posted by JoeVR
I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
Light out, or I'm sure there is a resistor that will cancel it when joining wiresOriginally posted by Speed View PostHow do I disconnect the brake wear indicator? I've joined the wires together before the plugs and the light is still on.
So just remove the bulb?
Roadworthy inspector might notice the joined wires or the extra resistor, much less likely to notice that the bulb in the instrument cluster is missing
1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
1996 Vento GL (white) - RIP
Ok cool. Now has new discs and pads just want the light gone as it indicates an issue that the car doesn't have. Thanks heyden and feenix.
Also wanted to turn it off with VAGCOM. Found instructions for a mk4 but not a mk3 so I tried the Mk4 instructions and it didn't work. So guess I have no choice but to pull the bulb.
Stefio this is a 94 model. Maybe it's just not lit up for you.
1996 Volkswagen Vento Sedan | Cars, Vans & Utes | Gumtree Australia Gympie Area - Gympie | 1121575317
for anyone after a cheap vento front end swap or vento parts car...Mk3 2.0. Mk3 VR6 CC. Future Mk2?
anyone achieved more brake clearance on a VR than the stock 288mm calipers? Looking at a few different setups to open up more options with some of my low brake clearance wheels
yeah 312mm seem too. wheels that clear on my bora (312) dont clear on either the 280 or 288mm mk3 setup.Originally posted by HaydEn View PostWilwood have more clearance.
312's do too don't they?
some Wilwoods would be nice
means I could stay smaller wheels
