Anyone have any recommendations as to where to get reasonably priced oem brake pads and discs for a 94 vr6?
Is the last thing I need to do before I can pass the car on.
Thank you.
my belt tensioner or pulley is making squealing noises on cold startup, should i replace the entire unit or just try and find a replacement pulley/bearing?
If oem discs/drum, the taper is built in so the bearing should just fall out.
Non oem stuff uses a tapered sleeve that has to be bashed in. But the bearing it's self is still loose.
So, you shouldn't have to hit the bearings out. If you do, need to pry/wedge a screwdriver through to the opposite side bearing
Thanks Hayden,
The outside came out but I've not pulled the inside out and am guessing I need to remove the abs ring first.
Will give it a go tomorrow.
If anyone needs some maroon panels let me know. I need to clear some space and have all doors complete with power window regs, glass etc, a front guard and bonner.
