Originally posted by browntown42
View Post
MK3 Random Thread
thanks buddy will keep that in mind!Originally posted by stefcio007 View PostVW MK3 Door Handles Seals Golf Jetta 1993 1999 NEW SET Aftermarket FOR 2 Handles | eBay
They used to be a lot cheaper, don't remember them being so expensive. I guess out dollar is sh-t.
will still consider if someone has some used ones locally though2010 Jetta 125TDi DSG
1994 Golf VR6 Manual
Went to order from vagtex to find that part number starts with 01M and listed for 1995 onwards. Mine is a 1994 model, 096 Trans.Originally posted by stefcio007 View Postvagtex USA, $50 shipped. Came with the filter, rubber seal on the filter, gasket (with the four metal inserts).
Penrite says ATF FS Multi is the preferred fluid. What did you get?
edit; lol, my price checker is indicating a 0.2% price drop on the Penrite ATF, good to see that my tool is working.
ECS Allows me to enter in 1994 but still lists part no. Beginning with 01M.
Both kits look same same but ECS is more expensive.
Will call vw again... to confirm I order the right stuff but if anyone on here can confirm, I'd be grateful.
Appreciate any help I can get, so I can service the Trans and move on.
Thanks,Last edited by Speed; 21-02-2016, 11:11 PM.Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Originally Posted by JoeVR
I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
I just checked on ECS using part number 095325429D (which is just the trans filter). It says "no longer available". There are some showing up on eBay.Originally posted by Speed View PostWent to order from vagtex to find that part number starts with 01M and listed for 1995 onwards. Mine is a 1994 model, 096 Trans.
Thanks,
Here's the link if you're interested, has photos too so that you can be sure.
Past - '95 VW Golf MK3 VR6
Have no idea what it should look like as I've not removed from the car. Wanted to get the parts before I strip it down.
Guess I'll have to call vw.Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
I will double check with my Haynes manual when I get home but I think that 01M was an evolution of the 096 auto transmission, so it would not surprise me if many parts are shared.
Just found this passage on wikipedia but would need to be double checked with a more technical source:
Originally posted by WikipediaBefore the 01M transmission, VW produced the 096 four-speed for Mk3 Golf/Jetta cars from 1992-1994. These cars will have a SPORT/ECONOMY switch near the shifter or on the dashboard to alter the shift points. Some of the 096 parts were held over for the 01M transmission, such as oil filter, oil pan, filler tube, gaskets, speedometer gears, skid plate, etc. These transmissions have different torque converters and many other internal parts that are not interchangeable.1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
1996 Vento GL (white) - RIP
Thought for the day - I see the 2.0 8v Neuspeed supercharger kits pop up for sale occasionally on Burnallthemk3s, would it be safe to say these would not work in a RHD car? Just purely judging by the S/C pulley sitting where the booster would be? Just seem fairly cheap for what they are, and would probably make a decently quick car with the right tune in a light bodied-car.
'15 Polo GTI
Past - '95 Mk3 VR6 Colour Concept
Early days but stats show changing the ATF and filter has improved mileage (km-atage?) by ~1L/100km. Will have a better understanding once I have a tank of travelling to uni and back added in, so not getting my hopes up too high yet.
Also, does anyone know if the electric window regs are the same if only the last 2-3 digits plus the letter are different. They visually look the same but I'm taking my motor from my broken reg and putting it into the new reg, so would like to know before I go buying.Past - '95 VW Golf MK3 VR6
They are yeah. We only got ADY's and AGG's though.Originally posted by himynameisbryce View PostOh really, I thought they were all ABA?SILVER '98 MKIII GOLF GL // BORBET TYPE A's
YELLOW '76 B1 PASSAT LS WAGON
WHITE '07 MKV JETTA 2.0 TFSI
FLICKR
