Car's looking tidy stu. Time to get it on the road though!
thanks man
ok so today i rplace the injector seal and then really gave it a good thrashing ... haha so now the injector stays in and runs good!
josh i figured out why it wouldn't idle straight away it need to warm up a lil because i still don't have the cold start and the aux air valve hooked up.
took it to dean today he seemed like it wasn't too bad i just went through what i needed to have done. its fairly ready just some things i need to do...
Fit small fuel pump - before the k-jet pump
Fit fuel pump relay
Tie d.s. rod end boot - torn atm
P.S. front brake line - has almost rubbed through
Fit cab seats - 3 second job scored some factory recaros for freeeeeee
Make reverse lights work - don't know whats going on...the wires are hooked up and when i take them off and touch them the reverse lights work....much be the switch or the linkages are not adjusted enough so that it properly engages with the switch.
Adjust linkages
Cut bumper bar holes in front guards
Raise the front
so yeh thats pretty much it i think..i need to go to a gas place and get a fuel pump relay and pick up my seats on monday and thats it...so i should be able to give it to dean on tuesday wish me luck
broooo...well it still leaks and now i can't get the reverse light switch to work
i am going to do a full re build on it and put an lsd in it but when i get some money. i start full time work on monday so should have some money soon enough
VW: it aint just a car, its a way of life There are few things more satisfying in life than finding a solution to a problem and implementing it
Adjust linkages - easy as!
Rust in D.S. headlight - replace
Rust in D.S. rear tail light - replace
Front seats do not tilt - need to find some
Adjust D.S. rear wheel bearing - easy as!
Clean around outer front CV boots - so i don't have to replace them
Fit fuel pump relay - so its not on when the ignition is on, only when it receives a signal from the coil- got one ordered in and will install it 2moz
Replace speedo cable - noisey
