Yup, Pete Jones is right, swop the bases over on the two seats.
19-20/6 Badgally Road, Campbelltown, 2560 02 4627 3072 or 0423 051737www.camdengti.com
ok so i have been reading about fuel pumps and things so i think i kow the problem with my car...it doesn't seem to want to work (sounds like its sucking air) when going around corners...i have read up on the pump and they say they can't seuck very well at alll! and should be gravity fed (pump lower than the fuel tank or a pump before it to bring the fuel to it...the pump atm is mounted a lil bit abot the tank and when the tank its less than 1/4 it doesn't accelerate out of them so i'm going to put a small electric pump before it to see if that cures it
i figured out why the car would run rough and then good and rough and good...
the injector seal on cylinder number one is worn too much...so when you give it to the car...this gets pushed out and the injector can still squrt but it creates a vacuum leak! so does anyone have the seals of another injector?
