Luke the VW fitment black diamond 280 discs should be here mid May, think there is a few sets of std ones left also.
From memory the only issue with using the earlier GTI calipers spaced out on the 280 disc is that the pads actually spill over the outside radius of the disc itself, not by much though. Thought about making an adaptor for this years ago but just went and got the 256 / 280 calipers instead
I have a set of VR6 calipers here ( thanks MattyT ) and will check them against the std corrado and 16V scirocco caliper for offset spacing differences, the differenc may well be just in the pad thickness'/ offset .
So does any of that make sense ?????
