Looks good Glenn. I know already that there will be a few jealous bodies on this forum!
Mk1 Scirocco- light Blue
Early Scirocco uses aluminium extrusion, very easy to bend out of shape, has a tiny slot in the rain gutter at each end for a dimple in the ali to clip into.Originally posted by Hydro View Postit is a chrome [ or stainless ] covering that clips
over the gutter. This may be a different gutter to yours.
Glenn.
Later versions use the clear plastic coated foil stuff, which with sun action goes brittle and yelows, usually falls apart trying to remove it. Held on with a black mastic stuff.Lots of MK 1 Scirocco's...
Cheers,
Grant...
Where will you put the rear number plate??sigpic Camden GTI Performance. VW / AUDI Specialists
the Sirocco sign on the rear needs the original number plate lights fitted in
to give it that " Lairy night time " look.
I was wondering if white neon strips would illuminate it better. Will try the lights first.
Maybe a switch to flickering light could be fun - or good for braking.
Glenn....with Old Scirocco to replace old Beetle.sigpic
Use it for brake lights, I reckon that would be killer
looking mighty fine Glenn. Well done.
Thanks, I am making some headway now.
Went through all the fuses replacing them and or cleaning ends.
Most things work now.......eexcepttt....rear washer, demister, and the right blinker is a bit dull. [funny that it works better on the Trouble light switch...]
Might try to bleed the brakes tomorrow - see if my son can spare 5 mins
I doubt it, it doesn't affect the safety of the vehicle at all, so i doubt you'd need it for RWC. There's nothing on my old RWC's that would indicate the need for this.
having said that, you'd kick yourself if it came down and bopped you on the head one day.
