VCDS Scan after putting the 3C0 Gateway back in:
Interestingly the Immobiliser still has a fault reading, but I assume this is because I didn't clear the faults before re-running the scan.
Code:
Monday,07,May,2018,21:43:42:38493VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 Chassis Type: 3C-VW46 (3C0) Scan: 01 02 03 08 09 10 15 16 17 19 22 25 36 42 44 46 47 52 53 55 56 62 65 72 77 VIN: WVWZZZ3CZAE038764 Mileage: 94960km-59005miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Sporadic communication error 1000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 22-AWD -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: Sporadic communication error 1000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: Not registered 0001 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-927-770.clb Part No SW: 02E 300 012 E HW: 02E 927 770 AJ Component: GSG DSG AG6 440 1982 Revision: 04844002 Serial number: 00000906161234 Coding: 0000020 Shop #: WSC 44551 111 44551 VCID: 120555150DF9DCD4BE-8046 No fault code found. ------------------------------------------------------------------------------ Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl Part No SW: 3C8 937 049 E HW: 3C8 937 049 E Component: Bordnetz-SG H54 2602 Revision: 00H54000 Serial number: 00000003285402 Coding: E6868F0700041A00470A00000F000000000A59435C000120000000000000 Shop #: WSC 05124 000 00000 VCID: 334BF09152A335DCD5-8066 Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB Component: Wischer 300709 022 0601 Coding: 00046997 Shop #: WSC 05124 Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB Component: RLS 260809 046 0204 Coding: 00208933 Shop #: WSC 05124 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb Part No SW: 3C8 919 475 A HW: 3C8 919 475 Component: PARKHILFE 8K H07 0009 Revision: -------- Serial number: 08740921503229 Coding: 100103 Shop #: WSC 12345 123 61029 VCID: 3245F5956DB93CD4DE-8066 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ Component: J0527 0030 Revision: 00032000 Serial number: 3C5953507CN Coding: 0001211 Shop #: WSC 05314 000 00000 VCID: 74C9338D172D72E40C-8020 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 002 0030 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1 Part No SW: 3C0 920 872 E HW: 3C0 920 872 E Component: KOMBI H02 0206 Serial number: 00000000000000 Coding: 160F00 Shop #: WSC 05314 115 00000 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040 ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod VCID: 277314C15E7B497C79-8072 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb Part No SW: 3C0 907 530 L HW: 3C0 907 951 Component: J533__Gateway H13 0152 Revision: H13 Serial number: 3300P098270529 Coding: FDA3FF07100202001003 Shop #: WSC 11111 111 45725 VCID: 2A75EDF58569741466-807E 3 Faults Found: 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 184 Mileage: 94962 km Time Indication: 0 Date: 2012.09.26 Time: 16:41:53 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 184 Mileage: 94962 km Time Indication: 0 Date: 2012.09.26 Time: 16:56:31 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 144 Mileage: 94967 km Time Indication: 0 Date: 2012.09.27 Time: 00:00:36 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3C0 959 433 AM HW: 3C0 959 433 AM Component: IMMO 052 0383 Revision: 00052000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151 VCID: 75CF0E891C576BEC3B-8020 Subsystem 1 - Part No: 3C0 905 861 G Component: ELV 027 0380 3C0905861G ELV 027 0380 1 Fault Found: 02823 - Requirements for Locking the Steering Column Lock not met 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 184 Mileage: 94963 km Time Indication: 0 Date: 2012.09.26 Time: 00:30:28 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl Part No SW: 3C0 959 760 E HW: 3C0 959 760 E Component: Sitzverstellung 1101 Revision: 00005000 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 2F43FCE1BE8B113CB1-807A No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb Part No SW: 1K0 959 701 AS HW: 1K0 959 793 P Component: J386 TUER-SG FT 1502 Revision: 71009005 Serial number: 00000934398701 Coding: 0005047 Shop #: WSC 05311 000 00000 VCID: 7F23ECA12E6B21BC61-802A No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 1K0 909 144 H Component: EPS_ZFLS Kl. 143 2901 Revision: 00H17000 Shop #: WSC 02069 000 90108 VCID: 2F43FCE1BE8B113CB1-807A No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 3C0-959-433-46.clb Part No SW: 3C0 959 433 AM HW: 3C0 959 433 AM Component: KSG PQ46 RDK 052 0412 Revision: 00052000 Serial number: VWZCZ000000000 Coding: 00910A0001860E76300494157008DFCE105801 Shop #: WSC 05311 000 00000 VCID: 75CF0E891C576BEC3B-8020 Subsystem 1 - Part No: 1K8 951 605 Component: LIN BACKUP HORN H09 9002 Subsystem 2 - Part No: 3C0 951 171 C Component: Neigungssensor 004 0611 Subsystem 3 - Part No: 3C0 951 171 C Component: Innenraumueberw.004 0611 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (R12) Labels: 5K0-035-456.clb Part No SW: 5K0 035 456 HW: 5K0 035 456 Component: KonzernAmp 8K H06 0340 Revision: -------- Serial number: BP218198613822 ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003 ROD: EV_AudioVerst8KanalBNO2.rod VCID: 67F354C19EFB897CB9-8032 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 5N0-907-801.clb Part No SW: 3C8 907 801 E HW: 3C8 907 801 E Component: J540 EPB3 VW-15417 0007 Revision: 010 Serial number: 00000000006790 Coding: 0000057 Shop #: WSC 05311 000 00000 VCID: 2C79EBED8F9D6A2494-8078 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl Part No SW: 3C0 959 433 AM HW: 3C0 959 433 AM Component: RDK 0453 Revision: 00052000 Serial number: VWZCZ000000000 Coding: 0161211 Shop #: WSC 05311 000 00000 VCID: 75CF0E891C576BEC3B-8020 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End-------------------------(Elapsed Time: 01:54)--------------------------
