Discover Media retrofit
  • #76
    I only just updated to the RCD330, but I'm thinking of dropping a Composition Media unit in my late 2009 R36 instead. Part number 5K7035200
    My gateway is SW: 3C0 907 530 L, HW: 3C0 907 951 - so from what I'm reading this will need to be physically upgraded. Correct?
    I have the white MFD, so I understand no CAN filter is required. Correct? If I do need a CAN filter, what exactly am I looking for? Google is not being my best friend right now.
    Is there anything else I'm missing?
    • #77
      Yes you need a 7N0 gateway.
      CAN filter is not required however the Composition Media unit needs to have been physically patched or it will trip Component Protection after 8 hours of runtime and be useless at that point.
      • #78
        Thanks Kamold - do you know if the gateway still needs to be at least a BC revision?
        • #79
          Can't say with certainty as I've never seen a composition media but it would be a safe bet to assume as much.
          Sent from my HTC 10 using Tapatalk
          • #80
            Final question... I hope!
            I can see you've upgraded to the B7 steering wheel, whereas I'm assuming those of us with an original 8 button, will have some issues.
            I purchased this adapter (part BD-ITQAC17820) to get all my buttons working on an RCD330 - would it be as simple as using the same adapter to get them working with Composition/Discovery Media?
            • #81
              Discover and composition media work perfectly fine with the older wheels.
              No adapter required like with rcd330.
              • #82
                Thanks Kamold - you've been an absolute superstar with all my questions!
                That is not what I expected - I thought an 8 button wheel would be a no-go immediately!
                If I'm not wrong, won't a Discover/Composition Media retrofit will still need an adapter harness like this to go from the older style pin assignment to new assignment for a MIB2 unit? I couldn't in your breakdown (only a new harness for the camera).
                Did you have a different solution?
                • #83
                  Yes there is a quadlock adapter harness required.
                  • #84
                    Hi so i have a headunit from mk7 2013 golf with nav etc. Wondering what model units i can upgrade and fit in there as my current one has an annoying buzz coming from the screen.
                    • #85
                      You can retrofit an MQB MIB2 unit.
                      Will also need a new screen (you can use either the 6.5 in or upgrade to 8 inch if you get the surround trim and vents also)
                      • #86
                        Great write-up Kamold - I followed it to the letter for my Composition Media install, and it all works a charm.
                        Except I can't seem to figure out the following:
                        1. Parking distance works, but I'm not getting an image on the screen, just the beeps when I'm near an object. Anything that looks like the right coding to enable it does nothing - have I missed something?
                        2. I have the dreaded "Steering column lock! Visit workshop!" warning on the MFD (and the steering wheel will not lock when parked), due to the 7N0 Gateway being incompatible steering lock - do I need to upgrade the steering lock, or is there a different solution?
                        Any ideas?
                        Code:
                        Sunday,06,May,2018,15:02:33:38493
                        VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
                        VCDS Version: 18.2.0.3 (x64)
                        Data version: 20180212 DS287.0
                        www.Ross-Tech.com
                        Chassis Type: 3C-VW46 (7N0)
                        Scan: 01 02 03 08 09 10 15 16 17 19 22 25 36 42 44 46 47 52 53 55
                                  5F 62 65 72
                        Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
                           Part No SW: 5K7 035 200 D    HW: 5K7 035 200 D
                           Component: MU-S--ER      H22 0245
                           Serial number: VWZAZ2R8010691
                           Coding: 028401000000000011110003001828001F0100C60020010002
                           Shop #: WSC 01357 011 00200
                           ASAM Dataset: EV_MUStd4CTSAT 001022
                           ROD: EV_MUStd4CTSAT_VW27.rod
                           VCID: 256F1EC924775B6C4B-8070
                        • #87
                          Any ideas?
                          Code:
                          www.Ross-Tech.com
                                    5F 62 65 72
                          For ops image on the screen you need to update to a newer park assist module.
                          Mentioned in my writeup I think? 1k8 module. It needs a wiring harness adapter as the pinout changed.
                          You can use a golf 7 module and reflash it with Passat CC firmware and parameter set.
                          Steering column lock error needs a wiring change in the steering column wiring loom.
                          Need to check my notes and get the details.
                          Bit of a pain you need to kind of lie upside down in the footwell but not too bad. Just need to bridge 2 wires from memory.
                          • #88
                            Yeah, you did mention it - I thought this might have been just for the overlay on the camera image, which I don't have.
                            I saw you did this in your Kamold's R36 thread, but doesn't this also involve an update to the CCM, or can you just bridge the wiring? Some other posts also indicate a CCM update is required.
                            Alternatively, now that the unit has been coded to the car with the new Gateway - what do you think would happen if I swapped it back to the 3C0 Gateway? Would it still work?
                            • #89
                              Sorry I'd forgotten about the ELV as I'd already upgraded my CCM previously.
                              Yes you need to clone your immo data to a new B7 CCM and modify the wiring to resolve it fully.
                              If you put the 3c0 gateway back in you won't be able to access the composition media unit via diagnostics, however if you leave radio at address 56 enabled, I think you should still be able to control the volume etc from the steering wheel...one way to find out...
                              Can you post a full autoscan so that I can see the full parts list and coding then I can look at the PDC issue.
                              • #90
                                Thanks Kamold - I should send you some beers!
                                Swapping back the old gateway was definitely the way to go. ELV issue gone, and surprisingly communication with the MFD is still as good as it was with the 7N0 gateway, and better than it was with the RCD510 - I can see what's playing, skip tracks, and see who's calling. Win!
                                Still no parking display - my guess is I still need the newer park assist module to communicate with the head unit, but in reality, I'm just guessing.
                                I've removed a bunch of thing from the scan like ABS and Door Electrics to fit in the character limit, as I figure they'll make no difference
                                VCDS scan with the 7N0 Gateway:
                                Code:
                                Sunday,06,May,2018,15:02:33:38493VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
                                www.Ross-Tech.com
                                VIN: WVWZZZ3CZAE038764   License Plate:
                                Mileage: 94960km-59005mi   Repair Order:
                                          5F 62 65 72
                                VIN: WVWZZZ3CZAE038764   Mileage: 94960km-59005miles
                                01-Engine -- Status: OK 0000
                                02-Auto Trans -- Status: OK 0000
                                03-ABS Brakes -- Status: OK 0000
                                04-Steering Angle -- Status: OK 0000
                                08-Auto HVAC -- Status: OK 0000
                                09-Cent. Elect. -- Status: OK 0000
                                10-Park/Steer Assist -- Status: OK 0000
                                15-Airbags -- Status: OK 0000
                                16-Steering wheel -- Status: OK 0000
                                17-Instruments -- Status: OK 0000
                                19-CAN Gateway -- Status: OK 0000
                                22-AWD -- Status: OK 0000
                                25-Immobilizer -- Status: OK 0000
                                36-Seat Mem. Drvr -- Status: OK 0000
                                42-Door Elect, Driver -- Status: OK 0000
                                44-Steering Assist -- Status: OK 0000
                                46-Central Conv. -- Status: OK 0000
                                47-Sound System -- Status: OK 0000
                                52-Door Elect, Pass. -- Status: OK 0000
                                53-Parking Brake -- Status: OK 0000
                                55-Headlight Range -- Status: OK 0000
                                5F-Information Electr. -- Status: Malfunction 0010
                                62-Door, Rear Left -- Status: OK 0000
                                65-Tire Pressure -- Status: OK 0000
                                72-Door, Rear Right -- Status: OK 0000
                                Address 02: Auto Trans        Labels: 02E-927-770.clb
                                   Part No SW: 02E 300 012 E    HW: 02E 927 770 AJ
                                   Component: GSG DSG AG6     440 1982
                                   Revision: 04844002    Serial number: 00000906161234
                                   Coding: 0000020
                                   Shop #: WSC 44551 111 44551
                                   VCID: 120555150DF9DCD4BE-8046
                                No fault code found.
                                Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
                                   Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
                                   Component: Bordnetz-SG     H54 2602
                                   Revision: 00H54000    Serial number: 00000003285402
                                   Coding: E6868F0700041A00470A00000F000000000A59435C000120000000000000
                                   Shop #: WSC 05124 000 00000
                                   VCID: 334BF09152A335DCD5-8066
                                   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
                                   Component: Wischer 300709 022  0601
                                   Coding: 00046997
                                   Shop #: WSC 05124
                                   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
                                   Component: RLS     260809 046  0204
                                   Coding: 00208933
                                   Shop #: WSC 05124
                                Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
                                   Part No SW: 3C8 919 475 A    HW: 3C8 919 475
                                   Component: PARKHILFE 8K  H07 0009
                                   Revision: --------    Serial number: 08740921503229
                                   Coding: 100101
                                   Shop #: WSC 12345 123 61029
                                   VCID: 3245F5956DB93CD4DE-8066
                                Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
                                   Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
                                   Component: J0527               0030
                                   Revision: 00032000    Serial number: 3C5953507CN
                                   Coding: 0001211
                                   Shop #: WSC 05314 000 00000
                                   VCID: 74C9338D172D72E40C-8020
                                   Subsystem 1 - Part No: XXXXXXXXXXX
                                   Component: E0221           002 0030
                                Address 17: Instruments (J285)       Labels:| 3C8-920-xxx-17.clb-SRI1
                                   Part No SW: 3C0 920 872 E    HW: 3C0 920 872 E
                                   Component: KOMBI         H02 0206
                                   Serial number: 00000000000000
                                   Coding: 160F00
                                   Shop #: WSC 05314 115 00000
                                   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
                                   ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
                                   VCID: 277314C15E7B497C79-8072
                                Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
                                   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
                                   Component: J533  Gateway H56 1682
                                   Revision:   H56       Serial number: 22041600F12287
                                   Coding: 350003
                                   Shop #: WSC 00046 123 12345
                                   VCID: 7BDB18B1FA733D9C4D-802E
                                Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
                                   Part No SW: 3C0 959 433 AM    HW: 3C0 959 433 AM
                                   Component:    IMMO         052 0383
                                   Revision: 00052000    Serial number: VWZCZ000000000
                                   Shop #: WSC 131071 1023 2097151
                                   VCID: 75CF0E891C576BEC3B-8020
                                   Subsystem 1 - Part No: 3C0 905 861 G
                                   Component:    ELV          027 0380
                                   3C0905861G     ELV          027 0380
                                1 Fault Found:
                                02823 - Requirements for Locking the Steering Column Lock not met
                                            000 -  -
                                             Freeze Frame:
                                                    Fault Status: 01100000
                                                    Fault Priority: 7
                                                    Fault Frequency: 1
                                                    Reset counter: 0
                                                    Mileage: 94963 km
                                                    Time Indication: 0
                                                    Date: 2012.09.26
                                                    Time: 00:30:28
                                Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
                                   Part No: 1K0 909 144 H
                                   Component: EPS_ZFLS Kl. 143    2901
                                   Revision: 00H17000
                                   Shop #: WSC 02069 000 90108
                                   VCID: 2F43FCE1BE8B113CB1-807A
                                Address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
                                   Component:    KSG PQ46 RDK 052 0412
                                   Coding: 00910A0001860E76300494157008DFCE105801
                                   Shop #: WSC 05311 000 00000
                                   Subsystem 1 - Part No: 1K8 951 605
                                   Component: LIN BACKUP HORN H09 9002
                                   Subsystem 2 - Part No: 3C0 951 171 C
                                   Component: Neigungssensor  004 0611
                                   Subsystem 3 - Part No: 3C0 951 171 C
                                   Component: Innenraumueberw.004 0611
                                Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
                                   Part No SW: 5K0 035 456     HW: 5K0 035 456
                                   Component: KonzernAmp 8K H06 0340
                                   Revision: --------    Serial number: BP218198613822
                                   ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
                                   ROD: EV_AudioVerst8KanalBNO2.rod
                                   VCID: 67F354C19EFB897CB9-8032
                                Address 53: Parking Brake        Labels: 5N0-907-801.clb
                                   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
                                   Component: J540 EPB3  VW-15417 0007
                                   Revision:   010       Serial number: 00000000006790
                                   Coding: 0000057
                                   VCID: 2C79EBED8F9D6A2494-8078
                                1 Fault Found:
                                1564 - Microphone 1
                                          B129B 13 [009] - Open Circuit
                                          Confirmed - Tested Since Memory Clear
                                             Freeze Frame:
                                                    Fault Status: 00000001
                                                    Fault Priority: 4
                                                    Fault Frequency: 1
                                                    Reset counter: 1
                                                    Mileage: 94964 km
                                                    Date: 2018.05.06
                                                    Time: 21:24:57
                                                    Voltage terminal 30: 11.6 V
                                End-------------------------(Elapsed Time: 01:58)--------------------------
