I don't doubt your advice and it's certainly true that the differences between MQB platform and PQ25/35 platform cars are not insignificant - but why can't OP's problem be solved by using the manual function in the MIB (i.e. MENU: Settings time and date)?
Don
You need to read/write the eeprom directly.
So either desolder it from the board and read in an external reader, or some in circuit tools with clips may work.
Sent from my SM-S921B using Tapatalk
2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC| 2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|3D colour cluster|Quad LED tail rings|Climatronics upgrade|Dynaudio retrofit|B7 RLine Flat Steering Wheel|3AA CCM|TPMS Direct|B7 Adaptive Cruise with Front Assist|Discover Media retrofit|PLA 2.0|Lane Assist|BCM retrofit|High Beam Assist|DQ500
It's not something most people bother with as it doesn't affect any other function.
Yes indeed, and maybe in the future a patch will be found to fix it (perhaps with a firmware update...)
Another thing, do you know if it's possible to get displayed the information of the "Since refuelling" Menu ?
I managed to activate the information of the "Since start" menu and on the "Long term" menu, but I can't find where to activate the one for the "Since refuelling menu"... , if there is a way to activate it...
Thanks in advance for your help.
Reason: forgot to add picture
Good morning mates,
any idea if it's possible to get displayed the information of the "Since refuelling" Menu, after having done the Discover Media PQ retrofit on my Golf MK6 ? Is there a way to activate it or any coding? Thanks in advance for your help.
Yes you will need to clear the fault for immobilizer and see if it comes back.
For the OPS display, you will need to put the 7N0 gateway back in and then check the following adaptation channels in 5F infotainment:
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A - change to "activated"
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus - change to "Terminal 15"
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering - change to "Available"
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus - change to "Terminal 15"
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc - change to "Activated"
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill - change to "Activated"
Hello VW mates,
I'm still working on my VW Golf MK6 Discover Media PQ rétrofit and I ordered a wiring harness adapter on Ali and changed the PDC Module.
The one that I installed has P/N. 1K8 919 472 C.
I also changed the gateway to 7N0 907 530 BF (S1673 - H55)
As I have no RVC installed, I have the PDC screen working fine, by showing the distance bars and the angle bars.
However, the angle bars they don't move when I turn the steering wheel.
And I would like to have the angle bars moving, if possible. (as on the picture in attachment)
Will this adaptation procedure mentioned by Kamold, make them work?
Can you please guide me on how to activate it?
I was looking for something else (how to change the mirror heater to come on with the rear demister - still looking) and came across info on updates to the SW version. I'm sure Kamold said mine can't as of the way the MIB2 has been wired into my Mk5.
If it can, I'm on MST2_EU_VW_PQ_P0367T and mibhelper.com says I can go to MST2_EU_VW_PQ_R0604T. Mr-fix says that if it is a 'T' Technisat you can't update from a 03 to 06 - you have to stay within the same range number. Although there is a work around.
Question is, is it worth it? What does upgrading get me?
That software version 604 is for the glass screen version of the MIB2STD PQ for the North American Passat NMS.
It doesn't add any new features or fixes.
The moving guidelines on the OPS screen are a function of the car model selected in bytes 0-2 of 5F. Can you post your full coding string for 5F or at least the first 3 bytes?
