Discover Media retrofit
  • Hey
    I see you are a gem at modifying VW audio. I have the same head unit as you do in my 2016 scirocco. I am wondering how hard is it to retrofit Dynaudio to it?
    Thanks Shane
    2016 Scirocco R - 2015 Polo GTi
    • Originally posted by shane_in_oz View Post
      Hey
      Thanks Shane
      How hard is matter of perspective...
      Speakers need to be drilled out then a new wiring harness installed to the dynaudio amp connected to the newly installed speakers.
      • Hi Kamold
        I’ve connected and codes my low rear camera today, but screen doesn’t switch to camera, or even say camera fault. Is the discover media not seeing the reverse signal due to older gateway, or have you experienced other issue to cause this?
        • Originally posted by rhinopower View Post
          Hi Kamold
          What sort of camera and how is it wired and powered?
          • Oem camera as previously used with rns510. Adaptor from Ali express for £8 as a short term solution to get some sort of camera working. I believe that the discover media takes reverse signal from the canbus to know to switch the camera on, but when reverse is selected nothing changes
            • How is the converter wired?
              If it has a reverse trigger wire connect this to 12v as well as the 12v wire. This will constantly power the rgbs to cvbs converter.
              The discover unit doesn't like any delay in seeing a video signal once reverse is selected.
              I had a traditional relay connected in my wife's car to a camera and it didn't work because it was too slow. I used a digital delay relay and now it works fine.
              • tried both +ve wires to perm live. As far as I could see, if the camera was unplugged it would just come up with an error saying camera not available if it didn’t see signal from the camera
                • Try another converter or try another composite video source connected to the discover
                  • You think 3c0 gateway has nothing to do with it? I’m going to upgrade to 7n0 and 3aa ccm now anyway
                    • You can throw a 7N0 gateway in there, but the 3c0 gateway sends the reverse CAN message on the infotainment bus already.
                      • [emoji897]
                        Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
                        Toy: 2008 GTI Pirelli | Sunflower Yellow | 3 Door | DSG | Pirelli Wheels | RNS-510 | 9W7 Bluetooth | RVC | Rear Sensors | Fog Lights | To Do: Mk7 Climatronics, MkVI MFSW, Colour MFD
                        • Checked adv measuring blocks, and you are correct, unit is receiving can signal. I have ordered Tiguan/b7 mib reverse camera. Converter must be faulty
                          • A composite camera without a converter will give a superior image.
                            • Hey agustinfx or others -- when you had to do some wiring in the bt module, can you describe it? Was your bt under the seat or in the armrest? My BT was in the armrest. I tried to follow what patrick did under the seat and I still can't get my mic to work with the mib2 stereo. Everything else is working so this is the last one and I would have thought the least complicated (vs audio, rear camera, integration with the MFI). Trying to figure out what options I have before replacing the mic and running dedicated wires from the mic location to the head unit.
                              Did anyone else do the mib2 upgrade with their bt unit in the armrest?
                              • What exactly was your bluetooth module? Was it an OEM module or aftermarket?
                                Impedance on aftermarket mics may not match the OEM ones.
                                What head unit did you have previously and if RNS510 did you have SDS (speech recognition) working?
