Replacing RNS 510 with RCD 330+
  • I own a Golf R Mk6 with reverse camera and dynaudio.
    A bit of confusion, however from what I gathered, the RCD330+ will give me degraded sound quality and lose ability to use MFD.
    However, the pros are that it integrates with the stock reverse camera and has CarPlay?
    Please let me know if I’m missing something as I’ve been hesitant to bite the bullet thus far
    • Originally posted by 7smurfs View Post
      You're correct apart from the reverse camera. If it's highline (bending guidelines) then not compatible. You'd need to replace the camera and control module.
      If it's lowline then you can use a rgbs to cvbs converter.
      • Originally posted by Jakeys View Post
        Also, I found another bug with the unit, if you have a max startup volume (Same as the RNS510 had) configured, every time a voice prompt comes through on Android Auto like say a navigation prompt, it resets the volume back to your max startup. So you may need to just turn that feature off if you're using Android.
        I'm being nitpicky bringing these bugs up, I think the unit is amazing.
        There is an update out, 5516, only for NoName that fixes the resetting volume issue. It adds a separate Voice Operation Volume control. It also fixes a few of the other bugs.
        • Hi all,
          I'm hoping to install the RCD330+ in my 2013 Passat alltrack. I've been holding off, waiting for a solution to the highline reverse camera problem which seems to have been going on for a couple of years now. I have a couple of questions for the hivemind:
          1. Has anyone tried this Xtrons decoder for a highline (bendy guideline) reverse camera (XTRONS CAMDCV01 Reversing Camera Decoder Box for VW Volkswagen Passat-in Car Diagnostic Cables & Connectors from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group)? Xtrons themselves arent too clear when I asked.
          2. is there a solution for installing an aftermarket camera that doesnt require running a new wire from the camera to the headunit? eg, can I install a new camera using the existing OEM wiring and then attach this to the RCD330+?
          3. can anyone recommend a decent VW mech in melbourne who can assist with some other mods (eg. upgrading park pilot to park assist)
          Sorry if these are simpleton questions, im new to this forum.
          Thanks!
          • There is no solution for the factory highline camera with an rcd330.
            I've used an aftermarket can rvc with discover media which works well.
            In theory it's the same generation head unit so should also work.
            • Hi guys, long time listener, first time caller....
              I recently purchased and installed an RCD330 into my 2010 R36.
              I mistakenly purchased the Desay version.
              Very happy with it, apart from the balance fader not being able to activate the rear speakers.
              I think the other day whilst listening to music, I activated the camera on my phone, and music was
              then softly playing through the rear speakers only.
              I was thinking of returning it, and purchasing a No Name instead.
              So my question is...
              Is there an easy fix for this problem with the Desay? Does the No Name have the same problem?
              Or should I get the No Name for more reasons, among the ability to update firmware?
              • Originally posted by Dams View Post
                I have the Desay version... everything works great so far..... i did have an issue with carplay (wouldn't connect after changing usb cable) but I reset the unit and everything is working fine now.
                hold down the power button for 5-10sec and then let go, you should see it reboot - this fixed my carplay issue.
                Current 2023 T-Roc R-Line 140TSI | Past 2015 Jetta Trendline 118TSI
                • The Desay worked great for me, except the rear speakers not working.
                  I've returned it and am waiting for the no name I've ordered to arrive, bit slow posting this one.
                  The rear speakers might not work with the no name either, but I'm hopeful this can be fixed.
                  I ordered the no name mostly because of the firmware update ability,
                  apparently there's a new version of carplay being released soon....
                  • So I got the No name version, had issues with beeping on start up, fader all the way on front left speaker
                    at every start up, and couldn't adjust equalizer which made the sound terrible.
                    Updated firmware and all issues fixed.
                    Easy.
                    • Considering buying one of these for my 06 Jetta, just wanted to make sure I have the right idea of what needs to be done before purchasing. Currently undecided between the A or B model, not sure if the Android Auto is worth the extra cost, if I do get a B model I plan on buying the cheaper noname version with MirrorLink and Apple Carplay then reflashing the firmware to one with Android Auto. Can someone confirm the following list should work with my car:
                      - Steering wheel adapter for 8 button steering wheel (my car has half height MFD if this makes a difference?)
                      - Dual fakra antenna adapter
                      - Updated Canbus: for this I was planning on getting one from a newer mk5 at the wreckers then just recoding it with VCDS to match my car - will this work?
                      Cheers,
                      Michael
                      2016 GTI 40 Years | 2012 Up! | 2006 Jetta - Sold
                      • Originally posted by MEL744 View Post
                        Cheers,
                        Michael
                        Yes, it will work.
                        • Have been following this thread for at least a year now - I have noticed in the last few pages that there is mention of the OEM RVC working with the 330+ if it is not the 'highline' model
                          I have a MY10.5 Mk6 Golf GTI, RNS510 as stock with the emblem RVC...my camera does NOT have the guidance lines - just video.
                          Am I correct in saying that I can use the 330+ with a video adapter? This is new to me if so.
                          • Yes you can use a lowline rvc with a rgbs to cvbs converter
                            • Originally posted by Mk R View Post
                              Disconnecting the under seat bluetooth is required as you'll no longer need it and it will conflict with your new RCD330, which has bluetooth and microphone inside the stereo unit.
                              After disconnecting the bluetooth module, can I just leave the cable hanging? I assume there's no other tweaks required to tell the car that the old module isn't required anymore?
                              Golf R 5 door United Grey | DSG | ACC | Leather | Bluetooth | 19" Talladega Black
                              • Originally posted by m_f View Post
                                I would guess that the CANBUS would report a communication error since it can't see the bluetooth module, although I don't think you would ever see it on the dash. Worth coding out if you have access to a VCDS cable somewhere, but not the end of the world otherwise.
