Originally posted by spec32
View Post
These units run varients of either WinCE or Linix, which means although they have a more limited feature set, they can run on much lower end hardware and boot near instantaneously. Many units have seen software mods or updates that greatly expand upon their original feature set with minimal side effects.
Most Android units I've ever looked into or owned take comparitivley an ice age to boot, need far beefier hardware to run and you end up relying on the manafacturer of the head unit to get compatibility and integration happening reliably, both in terms of car features and Android OS updates.
If you're someone who wants that increased level of power and the features that gains you, then maybe an Android based unit it best for you.
If you just want a radio that tastes like real radio, and has the ability to display Map/Song/other info from your phone (be it built in via built in bluetooth or MirrorLink/CarPlay/AndroidAuto) then these units are (for the most part) plug and play.
They're also popular because the previous generation of OEM head units to update to (RCD510, RNS510) where/are much more limited in functionality/performance as well as being far more expensive and required separate modules/varients for BT/USB, all of which needs more extensive coding than these RCD330 units.
