V6 Australia Maps
  • Has anyone ever had a dealer run a firmware update for them?
    • Unless it is absolutely necessary, they probably wouldn't. Just like with any other software in the VAG cars.
      Performance Tunes from $850
      Wrecking RS OCTAVIA 2 Link
      • Updated to Firmware 4120 this arvo Took 45 mins.
        All good Didnt lose maps or HDD music
        Map sort of disappeared till I parked outside for a while Then had trouble as North wanted to stay at top of screen.
        Put a route in (memory still there) and went for a drive of 1km Half way along it decided to reorient to direction up so is OK
        Apparently according to the manual it wont load a map if you already have that version.
        It took 10 mins before unit recognised it however.
        All good now to find out what I got for holding breath for 45 mins LOL
        ALs loaded Aussietigs POI file all good as well. Thanks
        • Unless your unit is one of the very first 2009, 2010 units you should be fine.
          http://www.vwwatercooled.com/forums/...-nz-69790.html[/QUOTE]
          I think mine may be one of the very first. I have a 2008 Tiguan with rns510. What is your recommendation.
          09 VW Tiguan Black 125TSI Auto - RNS510, DynAudio, Mdi, Rear View Cam, BT, Sunroof, Cornsilk Leather, Comfort Pack, Side Steps, 18" NY Rims, Tow Bar, Mats, Tint
          12 VW Polo Pepper Grey 77TSi DSG - Sports Pack, RCD510 and Mdi iPod, Comfort Pack, Blutooth, Mats, Tint, Panoramic Sunroof
          • Please read the thread that you mentioned to find out what revision you have.
            • Originally posted by Azzamataz View Post
              I think mine may be one of the very first. I have a 2008 Tiguan with rns510. What is your recommendation.[/QUOTE]
              Hold Setup button down till a menu with AM FM and Version information comes up and hit that top line is the unit model
              Then do as Kamold says
              • Thanks so far guys. I added the 381x firmware, and loaded v6 maps. Seems to be going ok but i havent fully tested it.
                I was finally able to access the secret menu and the delivery part number was 1T0035680D. According to the thread about RNS510 part numbers it seems that this unit was made from June 2011. My car was factory fitted in 2008 with the RNS510. Is this odd?
                  No, the firmware update changes the model ID to D — did the same thing with mine. It will still be a B unit, though, it doesn't alter the hardware.
                  • I'm not that's the most way to accurately check the model. I have a C unit and one of the firmware upgrades changed it to appear as a D model now. Checking with VCDS or pulling out the unit to check the sticker is better.
                    Audi A3
                    • Originally posted by Ryan_R View Post
                      Correct Mine was a C and now shows as a D
                      However if Azzamataz's unit had never been upgraded it should have shown as the original model.
                      I think mine did before we started playing with it
                      • V6 maps are working fine in my RS Octavia. the route line is pale blue now. was it dark blue before?
                        I haven't heard any location based directions to see if it says 'dumb' or whatever it is.
                        don't have an option to change the voice, only the chick still. but she is ok for a pom
                        • Picked my new Passat up tonight and upgraded the maps. Thanks for uploading them, was a breeze to DL, burn and install with all the great advice available on here.
                          2013 Passat tdi 130kw/380nm - Autumn Brown, Driver Assistance & Visibility Package, 12 way Power Seats, Adaptive Cruise Control, RVC, Auto Tailgate, Black Nappa.
                          Full Nanolex paint, glass and wheel protection.
                          • it seems the maps still aren't complete...I had a "turn right towards dummy" when heading north in the tunnel tonight ( it was directing me towards Manly). but it has worked for other directions, so getting there.
                            Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
                            • Re: V6 Australia Maps
                              Maps are definitely still not great. Have also had dummy directions and as I've pointed out some really poor route selection due to incorrectly recoreded speed limits on roads.
                              The male voice is with 4120 firmware, not v6 maps.
                              Sent from my HTC One X using Tapatalk 2
                              • hmm I have 4120 firmware. or do I? I should check that
                                meh, doesn't worry me. maybe secretly I prefer a woman to tell me what to do
