Firmware updates for European RNS510 units
  • #46
    after i imported the PersonalPOi it told me succecefully imported, but when i go and back it ask agai to import them,
    when i go to navigate i dont see POI and also can't find POI on System/Map/POI
    4020 sees PersonalPOI.DB3 allow to import them but not to selecte them ( so not working)
    3810 doesnt see PersonalPOI.DB3 neither EDP/POI.db3( so dont know which formate does it read)
    conculusion both are not working for POI unless devoloper can advise
    • #47
      I installed fw 4020 original and the 4020 with 90/5/5 partitions with success in my RNS B but couldn't install the maps because there is no space in HDD. Then I tryed the 75/20/5 one but the iso could not load (DVD-error). I have use different media, burners, MacOS X, Windows 7, downgrade option, reset memory, downgrade to 2760 but no luck. Then I tryed the new one jamerson upload but there is no new partition map in there. Can someone upload a good 75/20/5 iso (like the 90/5/5 with VIM enabled) please. Thank you
      • #48
        Hello !
        I read the whole thread but finally I am a little bit confused:
        - Sometimes you are revering to a partition of 75/20/5
        - Sometimes 90/5/5
        I installed at my (C8 /C9) Navi the 4020 from the first post, but partition did not change; I have 18GB space for Music...
        ...as far as I know I should have a 40GB HDD (or only 30?), anyhow this is a little bit less (or more cal. with 30GB) than 50% !??
        How big is your space for music?
        and
        Am I allowed to install the 90/5/5 Firmware in Europe??
        Greetings
        Roger
        Skoda Octavia 2011 - 2L TDI - RNS510 (0xC801 - 06)
        • #49
          I think, that 4020 for Unite A/B/C doesn't change size of partitions to 75/20/5, there is something wrong.
          I had version 2760, I upgraded to 4020, partition size stays 20MB/10GB. All the data remains unchanged on HDD. After downgrade to 3810 the partition was resized to 15/7.5/7.5GB, no data were found on the HDD - all was deleted. Then i upgraded back to 4020, partition size stays 15/7.5/7.5GB.
          I think, in 4020 is missing a procedure for resizing of partitions.
          Original version 4020 doesn't have this procedure too. There is this warning: "This upgrade will not create the new partitions required for the new POI system if you upgrade from 1xxx/2xxx. Upgrading from 3800-3910 is required so the new partitions are created."
          ---------- Post added at 10:41 PM ---------- Previous post was at 10:32 PM ----------
          One question: I downloaded this image from the very first post:
          Firmware 40xx - Link (thanks to jamerson) [URL="https://rapidshare.com/files/1195943676/ISO9660.rar"[/url]
          I opened the file version.txt in this ISO, there stands:
          #VwSwIndex:3810/3816/3810/3818/3814/3810/3810
          So: Is this FW 4020 image or 3810 image file?
          • #50
            Sounds like I will have to have the ISOs created as maybe they were not built correctly. I thought that the previous instructions were clear but maybe they weren't...
            European maps are too large, you cannot use 90/5/5 ratios as there will not be enough room for the map data.
            • #51
              Please Kamold make a new iso with correct 75/20/5 partition and VIM for European users. Thank you
              • #52
                Yes Kamold, please ....
                I think, there is a little misunderstanding on the first page of this thread.
                Post Nr. 10:
                Europe 3810 you can download ready ISO
                4XXX is coming soon
                Post Nr. 1
                So both links are identical, what is correct now?
                • #53
                  OK first post updated with a new link for 402x firmware for older units. Has 75/20/5 partition ratios.
                  Will make and upload the other ISO soon.
                  • #54
                    Simply the best
                    Thank you!!!
                    • #55
                      Upload failed, have to try again...missing megaupload...
                      • #56
                        Thank you Kamold!!!
                        The first modified firmware you posted a short while ago is intended for the A unit version, but can be used in B and new unit versions, am I right?
                        • #57
                          Yes it can, however I am uploading also the standard 402x firmware for C unit and later units that has VIM, secret menu and 70/20/5 partition ratios.
                          It will take a while so won't be available until tomorrow my time. I will update the link in first post once it is uploaded.
                          • #58
                            Hi,
                            I've uploaded the ISO with the European version here:
                            It works fine. It's the version I've installed.
                            Regards!
                            • #59
                              Hey Andreas,
                              if you are EU user and your Device B or C use this FW if not please provide more information and we will help you
                              i already pm Kemold it wrong file on the first post he will edite it soon
                              Originally posted by Capy View Post
                              Hi,
                              Regards!
                              are you able to get your EU POI Working with this FW?
                              • #60
                                The links are correct, not sure what you are referring to Jamerson? I just checked the link again.
                                Links now available for all units.
