You should not need to downgrade first, you just need to enable downgrade in the hidden menu.
There may be a problem with the ISO that you have created.
I will try and find some time later to make and upload the ISO..
2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC| 2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|3D colour cluster|Quad LED tail rings|Climatronics upgrade|Dynaudio retrofit|B7 RLine Flat Steering Wheel|3AA CCM|TPMS Direct|B7 Adaptive Cruise with Front Assist|Discover Media retrofit|PLA 2.0|Lane Assist|BCM retrofit|High Beam Assist|DQ500
i used Daemon tool, i just deleted the file and replaced the one you uploaded for me and i saved the ISO,
One thing I have noticed at 402x firmware is the unit seems even MORE picky about CDs.
I never had any issues with mine in the past but after upgrade to 402x I had to use xpcdburner and track at once recording to get a custom boot screen CD to be accepted.
Maybe its worth doing a downgrade to 276x first and then upgrade to 402x....
i managed to install the new Firmware the map is copied to the HDD
the file i uploaded is fine,
one more question
can i save Western Europe, and Easter Europe to one HDD?
one more question
can someone please advise?
That's good news.
Did you go down to 27xx then up to 402x or did you manage to load 402x by itself?
You can only have one set of maps loaded to the hdd. You can put in the DVD if you are in Easter or Christmas Europe.
That's good news.
thank you for the answer
no i didnt load back to 27xx but i enabled allow downgrand,
the map is copied now to the HDD and all is fine
thank you for the support,
please find the iso i uploaded for others
Thanks, where will I find the iso? I will update the guide.
Thanks. I presume that is the 402x firmware ISO?
Any chance you could also upload the 38xx firmware ISO with Euro partition sizes as well?
Then we can have a complete guide for Europe with pre-made images...
