See the post immediately above yours....
If you are repartitioning the hard drive you need the map disk. So if the current firmware is 2xxx series then the hdd partitions will change.
And if you are loading a custom firmware with modified partition ratios the hdd will be wiped also.
So you need to have the map disk on hand for the upgrade.
2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC| 2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|3D colour cluster|Quad LED tail rings|Climatronics upgrade|Dynaudio retrofit|B7 RLine Flat Steering Wheel|3AA CCM|TPMS Direct|B7 Adaptive Cruise with Front Assist|Discover Media retrofit|PLA 2.0|Lane Assist|BCM retrofit|High Beam Assist|DQ500
The maps partition is not a format that you can access from a computer.
You need to use the DVD drive. If the DVD drive is broken you'll need to replace it.
I simply wanted to avoid having to buy a box of DL discs when I only need one, £20 is cheapest I've seen. I'd load v8 maps without poi's if I could find a reliable link.
You could always buy a genuine version of the map which would probably cost a bit more than 20 pound.
You are in the wrong country I bought a 10 pack of D/L dvd's for $19 and thought that was expensive
Bought some discs and burned v9 maps. I installed v8 maps the other night but with the v9 it appears to be hanging, and if you press eject the status bar is not increasing. What am i doing wrong?
We only have Aus V6 so dont know. I see you upgraded to 4120 Just DONT USE THE AUSTRALIAN version as the map partition is too small for European maps
