Firmware updates for European RNS510 units
  • Personal POI feature was released at 3xxx series firmware. It works.
    If you load 4120 on your unit there is a chance you could damage the radio board.
    • Hello Kamold,
      I've got:
      Delivery part number: 3T0035680A
      HW version: H11
      SW version: 1304
      HW vehicle: 0xC201
      HW radio: 0004
      I tried to update the maps to V12 Western Europe but that failed and now I got no maps installed at all. I suppose it failed because (as I learned later) I have only two partitions and not enough space for the new maps.
      From what I read here I get the impression I should install firmware 4020 and can then install the V12 maps, is that right?
      And if so, can I install 4020 directly or should I first upgrade to some 27xx version?
      2009 Skoda Octavia Combi 1.8 TSI DSG
      • What firmware version are you running? Is it one with custom hdd partition ratios? If so is it one for Europe? You may not have enough space for the maps if you have changed from the default settings.
        • I live in Europe and just bought the car second hand there. I did not change the firmware or partitioning, so I suppose the firmware is the original 1304 and the partitioning will likely also be original (don't know how to verify this).
          • Even with original firmware you can load New maps, the space for maps is less with 3 partitions, not more. If the load failed it's probably a bad map disk.
            • Hello Kamold,
              I have an RNS510:
              Part number: 3T0035680A
              HW ver: H42
              SW ver: 2724
              Can I update to firmware 4120?
              Thanks, Rob
              • Yes you can
                • Great, thanks for your fast reply!
                  • Hi Kamold,
                    Can you please help me? I have read this entire thread and googled a lot. But I'm not entirely sure to which version I need to update.
                    I'm thinking first to version 3810. But not sure which 3810 I need to pick. The normal one or the Update Modified (Regensburg syndrome, MP3 VBR Resume for revision A, B and C head units)?
                    And after 3810 to 402x from this thread.
                    Is this correct?
                    Thanks in advance!
                    1T0 035 680 B
                    HW H03
                    SW 0900
                    Europe
                    • Just load 5238.
                      • I have successfully update from 0900 to 5238.
                        Thanks!
                        • Originally posted by bjlevi View Post
                          Thanks!
                          Good stuff
                          • Hey Kamold,
                            I have a Volkswagen Passat 2.0 TDI from january 2008.
                            The RNS510 setup shows the following version information:
                            Delivery part number: 1T0 035 680A
                            HW-Version: H04
                            SW-Version: 1020
                            SV SW-Version: C_EU_5.540_t730
                            HW Vehile: 0xC001
                            SW Vehicle: 0x44261C02
                            HW Radio: 0003
                            Can I upgrade to Firmware 4020 modified?
                            I would like to use the new functionality like Speed Limit display etc.
                            Are there positive test results for my configuration?
                            The information on other sides like my-gti.com and vwnavi.com is confusing me because some users say that fw 4020 can only be used for 1T0 035 680D of higher.
                            If the upgrade would go wrong, can I reinstall the current version 1020 which I have on CD?
                            I will be gratefull if you could give me information if I can/should do this.
                            Koos
                            • You can install 5238.
                              • for Euro firmware version...use 5238 from here VW RNS 510 & Skoda Columbus I - Firmware GUIDE & DOWNLOADS
                                MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
                                2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
