Originally posted by roku067
View Post
This is a sticky topic.
I Agree, i've actually already mid-way through completing a RCD330, just having issues with the OEM genuine rear view camera.Originally posted by Hillbilly View PostAs said above 5238 is enough as the units are almost museum pieces now and no updates much
Excellent!! I'll give it a go!Originally posted by kamold View Post
Try it it either will or wont Waste of time really as no maps for them now anyway Last one was $175 3 years ago Better to buy a newer better unit than waste time and money on an antiqueOriginally posted by yuruiyou View PostHello,
My SW Version is 4090 and HW Version is H71.
Can I do some Firmware Upgrade?
thanks2021 Kamiq LE 110 , Moon White, BV cameras F & B
Au iso images
Shared Links to both disc iso files
RNS510 OEM AUS firmware update 6276
RNS_510_OEM_AU_FIRMWARE_VER_6276.iso - Google Drive
Hawkedit: Removed copyrighted maps. If you can provide a link to an official source I'm more than happy for it to be shared.Last edited by The_Hawk; 13-10-2023, 06:56 AM.
wait, sorry, what is this?
newer version?
i got hw ver h09
sw ver 5238 can i use this?
i got no sound and language on display is stuck in german... thoughts on if this may help?
5238 was what most of us used and it worked fine.Originally posted by Mattafro View Postwait, sorry, what is this?
newer version?
i got hw ver h09
Make sure 6276 isnt for Euro units as partitioning can be different as maps are a different size.
Is so long ago cant quite remember what was what. Eurocarupgrades had the latest map for about $1752021 Kamiq LE 110 , Moon White, BV cameras F & B
Originally posted by Hillbilly View Post5238 was what most of us used and it worked fine.
how.... do i find out if 6276 is for euro or here in oz? i mean.. without installing it...
what gets me is.. my unit has the fancy reverse camera with lines etc. how does upgrading the firmware not effect any of this?
i just want my sound back.. crying face emoji.
You have the rechesburg????? syndrome and if you look back quite a way in the threads you will see it was quite common for a while and the solution to fixing it is there also Need to go back about 7 years or so Page 87 first post tit and go for a drive for 30 mins to let it find where it is ONLY PUT 6276 if you have A LATE MODEL DAB model 5238 is enoughLast edited by Guest001; 24-04-2024, 06:01 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
cant be the drive,Originally posted by Hillbilly View PostYou have the rechesburg????? syndrome and if you look back quite a way in the threads you will see it was quite common for a while and the solution to fixing it is there also Need to go back about 7 years or so Page 87 first post tit and go for a drive for 30 mins to let it find where it is ONLY PUT 6276 if you have A LATE MODEL DAB model 5238 is enough
i drove it to sydney and back (im in wollongong) thats about 2 hours there and back... its in german, wont change back...
also, i have lost all sound in the unit..
im happy to do a firmware update, would rater reload what i already have though to keep it the same,i tried to load the verion on page 1 but it tells me in trying to downgrade and it wont allow it.
fyi, delivery part number 1t0035680L
hw version h09
sw version 5238
map version 7920
the error code i get is 010304
it says target is loaded with 5670902 and inserted media is the same..
wont let me re-load it.
any way to force a reload? to try and get the english language pack and stereo sound to work?
realy appreciate your help so far.
you would need to downgrade to an older version first, then 'upgrade' to the desired version.Originally posted by Mattafro View Postis there a way to reload the firmware that it already has?MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
You can reload the same version. It's considered a 'downgrade' as it's not going to a higher version.
Enable developer mode and then go into the menu and enable software downgrade.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
well, I stand corrected. Cheers J (@kamold )Last edited by FJ Steve; 29-04-2024, 09:51 PM.MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
