Originally posted by tonymy01
View Post
Summary of Bluetooth Options for RNS510 & RCD510
Have a look in the Guides section of Redirecting... for some extra installation ideas/photos
All installed and working nicely. Including BT streaming from Tune in Radio to my ancient RCD310. Install only took me an hour and a half and the tips of using a piece of coax for poke through was excellent thnx. Worked a treat through head lining and not need to remove sunvisor or vanity lights to gain access. Didn't get the foam tape but used some medical micro-pore tap to wrap the mic cable so it does not rattle in the head lining.
Unfortunately I broke off three of the head units facia clips. Although I was careful and suspect this may have occurred during a previous service. Should stay on without them as it has 7 in total.
What s the go with the all the VCDS error messages the module throws. Is there some coding I can do to stop them or do I just live with them.
Address 77: Telephone Labels: 7P6-035-730.clb
4 Faults Found:
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
13636352 - Control Module Not Coded
U1013 00 [009] - -
9457937 - Telephone baseplate
B1051 11 [009] - Short to Ground
9458449 - Cellular Antenna
B1053 11 [009] - Short to Ground
Confirmed - Tested Since Memory ClearGolf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
Try setting this to 'Not Installed' - refers to the phone shortcut buttons on the roof that you wouldn't have:
Thanks that fixed it. Even though practically the unit was working fine - in the coding screen VCDS recognised the module had not been initialised and offered to do so with default coding. so I let it do that.
Then I recoded Byte 7 as you suggested as not buttons fitted. Then Byte 6 as no baseplate fitted so no diagnostics for it required. Finally Byte 5 to make Antenna diagnostic inactive as not fitted either. All good now, with no faults. Thanks heaps.Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
Originally posted by logger View Post...Unfortunately I broke off three of the head units facia clips. Although I was careful and suspect this may have occurred during a previous service. Should stay on without them as it has 7 in total...
Originally posted by logger View PostBeauty thanks. Just what I needed to know. Yeah my retrofit kit includes that blown foam mount too. Will whack it under drivers seat. Thnx.---
Sweet. Mine ended up looking just like that so I am glad I asked. Thnx. I ran the wires in beside the seat harness you can see in your pic.
BTW build date on my module was only 5 weeks ago, late Aug 2013, so Carsystems stock is right up to date.Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
hi all,
i have been reading the options available through this thread with regards to adding bluetooth for the RCD510 in my '11 gti. looking at logger's posts it seems the unit below should be a treat when hooked up (all options ticked bluetooth streaming, voice control, mfd)
VW Bluetooth KIT 7P6035730L - Retrofit - Newest Version
is there anyone based in melbourne here that offers installation (dealer, vw specialist)? i am not familiar with the coding required and the last posts in this thread regarding installation from my search may be outdated? any help would be appreciated before i give my credit card a working out.
thanks
hilman
Honestly you're better off going DIY or asking an experienced forum member who's done this already rather than looking for a workshop. Ask in the VCDS forums for someone who can do the coding afterwards.
Originally posted by Ryan_R View PostHonestly you're better off going DIY or asking an experienced forum member who's done this already rather than looking for a workshop. Ask in the VCDS forums for someone who can do the coding afterwards.
thanks for the advice. i sent a message to carsystems asking what is required for installation and they came back with, this is the best option for RCD ..
VW Bluetooth KIT 3C8035730C - Retrofit -
can anyone here clarify the difference?
also ryan to your point, i might have to start making some friends with people here who have done the install before
That one can also be used in rSAP (remote SIM) mode.
Pros:
Has antenna to improve call reception
Can send SMS via head unit
Saves phone battery
Cons:
Not all phones support rSAP (although you can still use it in the UHV mode as per the other bluetooth module you listed)
Disconnects your phone's 3G so you lose the Internet for email delivery and other apps
There's an even newer version of the rSAP version that now includes WiFi hotspot (shares your phones data as a WiFi hotspot for others in the car to use I think) if you want to look out for it - model numbers ends in a D iirc.
Originally posted by Ryan_R View PostThat one can also be used in rSAP (remote SIM) mode.
Pros:
Saves phone battery
Cons:
thanks for the swift info Ryan! looks like the previous 7p6035730l will be suffice for me, more interested in just having what is now stock standard for most cars - bluetooth connectivity. doubt i will be looking to use rSAP.
Enjoying my BT retrofit. However I have noticed that my 7P6035730L installation is missing the phone battery gauge and iPod connected icons on the white MFD. I simply see
Underscores beside the BT icon
..instead of seeing
Battery and iPod status icons.
Regardless of phone connected. Iphone 5, Nexus 4 no battery info gets to the MFD on my installation.
A quick Google tells me the missing icons can occur on both 76P & 9W7 modules. I am hoping it is simply a coding issue. Further I do not think it is because I only have the toy RCD310 because people with up-spec radios report same issue. Anyone got the battery icons working and VCDS so we can compare coding? Ross Tech do not seem to have coding for this idiosyncrasy, but that does not mean it does not exist. Just may not have been recognised yet.
Mine shows
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00AAAA63112811
Coding: 0A00000000010110Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
fwiw I don't have those icons either, actually forgot about them when I upgraded.
