Originally posted by gonsped
View Post
Summary of Bluetooth Options for RNS510 & RCD510
To get Bluetooth audio streaming and be able to control the iphone etc via the headunit you need the latest version of the RCD510 (version 3) started to be released in August i think. model: 1K0-035-180-AE
This is the unit: http://www.youtube.com/watch?v=RdnnCYK6FUs
u can still stream music using a2dp, the issue here is that u can't see the track info (album & artist) unless u have a specific model.Originally posted by gonsped View PostThe fact that the Bluetooth manual claims you can stream music over A2DP is very misleading if it required a specific radio model.
older models just say "BT Audio". u can't change (<< , >>) tracks. this needs to b done on the device (iPhone) itself.
newer models display the track info, plus enable you to change tracks.MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
Darkshadow - you are correct. The feature to see the track and changing it on the radio I don't need. I have the phone mounted on the windscreen and I am happy enough to change it there.
Just got the car back from the dealer. They claimed the wiring was incorrect. So somehow they removed the auxiliary connection (which was working) and now it can BT audio stream with A2DP. Not sure why they had to disable one feature to get another working? =/
Another thing I noted was, although BT phone calls was good - the A2DP feature has an audio lag - something between between 1 and 2 seconds. You can really notice when the iPhone4S is playing a video. Its rather annoying - but I think it's the Parrot type system causing this as I have several bluetooth headsets, speakers at home and A2DP never lagged on them. I tried the new Skype for IOS which allows BT headset and the lag is very prominent when you do the Skype test call.
Ah well, at least this shows that iOS 5 is definitely not the issue here.Last edited by gonsped; 19-12-2011, 09:40 PM.
Still a little unsure as to which unit to buy for my '11 golf gti mk6 RNS510.
Any ideas? 9w7 or 9wz? I've read some issues with fitting the 9wz in the golf. I was hoping to buy it off eBay from the spanish dude.
VW 9WZ Unit eBay
All depends on if you plan to use the RSAP (Remote SIM) features (if your phone supports it). If yes, get the 9WZ, if no, go for the cheaper 9W7.
You can always get the 9WZ and not use RSAP as well. Just has an extra antenna that you have to install somewhere.
The only one who has got that working to my knowledge is VRaptor. He had the 9w7 kit and the RNS510 with firmware updates. So you are in with a chance.Originally posted by pabs10 View PostDoes the 9WZ have any other features over the 9W7??
I want the song name to come up on the screen over bluetooth and I want to be able to control the bluetooth using MFSW
Is this possible? Also is it possible to update the 9W7 firmware yourself?
By "update the firmware" do you mean update to provide more features (ie version c to version G)? I don't think so, but happy to be corrected.
Either way you will need coding.
Al..2013 MY13.5 Passat V6 Highline Wagon. Watch this space
GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
Link to Vraptor's stuff. http://www.vwwatercooled.org.au/foru...-31461-45.html
Seriously, while it is hard work, have a read through the first few and last 10-12 pages of this thread.2013 MY13.5 Passat V6 Highline Wagon. Watch this space
just thought i'd mention that I also see the track name, album and artist on screen when streaming via A2DP. I have a 9W7 bluetooth unit (7P6 035 730 F), an RNS510 running v3970, and an iPhone 4S running iOS5. Buttons on RNS screen allow skipping tracks, and play/pause.
Great post & very informative. Thanks.
Would you know if the B7 SatNav uses Next G or is it still relying on GSM. A friend of mine has a 2yo Tiguan & she noticed coverage drops out in country Vic even though her phone has signal. That would be annoying!!MY12.5 B7 V6 Passat wagon in Mocca Anthricite with Panoramic sunroof, SatNav, Driver Assistance & Visibility Package, Adaptive Cruise, Park Assist 2, Auto Tailgate,Tint, Towbar & RVC
Have you done the VCDS coding?
