Help needed - RNS510 recovery boot disc or working link for downloadable image
  • Help needed - RNS510 recovery boot disc or working link for downloadable image
    Help needed,
    Can anyone provide a working link for a downloadable image to create a recovery disc for a RNS510 rev B unit.
    Any help greatly appreciated ☺️
    2006 Jetta TFSi, 2014 Passat Alltrack, 2010 Jetta 1.6 TDi manual, VCDS MicroCan
    Did you read the first sticky Is all in there
    DepositFiles
    Try this was on about -page 71 of that thread
      If the unit is till responsive you should be able to use the standard firmware, otherwise the recovery disc should see you right.
      The links are all on page 1 and should be good. (The files are all hosted on VWWatercooled too )
      Firmware updates for RNS510 units in Australia/NZ
        Thanks guys, will have a crack at this shortly. ��
          Links arent working Kamold I tried twice today and get Website being updated etc and the GPS underground is kaput as well. THe link I posted works and I d/loaded the iso this morning
            ...bugger, still not working.
            Anyone have suggestions on who I can send out this unit to for inspection / repair and update? I'm in the virus capital, Melbourne...
            I have a genuine Volkswagen map update disc also Version 8.
              Originally posted by kamold View Post
              Firmware 523x - Link
              Alternate link
              SNIP
              Refer to Unofficial 272x software and SWL recovery CD for 'recovery' firmware if the load fails and your unit becomes unresponsive.
              Alternative link (VWWC)
              These links should work (at least the WWC ones anyway)
                OK you tech heads out there, Ive attached two screen shots of the end result of the two burnt CD's I created to fix the 'boot-looping' RNS510 radio unit, which neither of these CD's are working.
                If anyone can see a reason for not booting up, please let me know... thank you.
                  Use a DVD and burn it slow like 4spd
                    Thank you, I'll have another attempt on a different computer. 🤞
                      Originally posted by macdoc View Post
                      Thank you, I'll have another attempt on a different computer. ��
                      Did you get my PM?
                      MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
                      2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
                        I'm curios macdoc to see if you have used the Recovery file I sent you.
                          Hi Steve, sorry, only just seen your post...😄
                          I've just downloaded it & will burn it tonight.
                          Will let you know next week.
                          Thank you.
                            Hi Steve, YES success, thank you.
                            Now, the next issue is my map version 8 disc does nothing when inserted in the drive. For testing purposes, the unit will play a DVD movie disc without any issues.
                            Any tips on loading maps after using a recovery disc?
                              Do you have a more up to date Firmware to load onto the system?
