VAG-COM scanning, who can help
This is a sticky topic.
  • Correct- mk6 gti
    Sent from my SM-G973F using Tapatalk
    • Originally posted by Matt86 View Post
      Is the OP currently active, are we able to update the original post with current members?
      It is going to be tough to trawl through 12 years of posts and see who is still around. ��
      If current users don't mind sending me a PM I'll add a list to my original post though.
      • Maybe time to start a new clean thread, close this one (with a link back to this one for reference) to draw a line in the sand. Up to you if you want to keep this up Gavin. If you want to start a new thread I can do all the admin actions to pin it and close this one out.
        People should include suburb, state and postcode to help with location and maybe what sort of cable they have.
        For me: Aaron - Kilsyth VIC 3137 - Genuine RossTech
        • I'll do it at the weekend Aaron.
          Start a new thread and lock this one up.
          In the meantime folks. Please feel free to PM or post below with your details as Aaron suggests. Include the type of cable and suburb.
          • Julian
            2153 North West Sydney
            VCDS
            VCP
            OBD11
            ODIS
            SVDI
            Etc...
            • Damien - Semaphore SA 5015 - VCDS - Micro CAN - most functions (but not all) with MQB cars
              - Tigger73's 125TSI Build
              • Vcds
                VCDS HEX+CAN Banora Point/Tweed Heads area
                • Lucas - Mayfield (Newcastle) NSW 2304
                  VCDS (cant do MQB generation, but works on anything older like Mk6/Mk5 Golf etc)
                  Carista (which does work on MQB generation vehicles but isnt as powerful as VCDS)
                  2015 Audi SQ5 - SOLD
                  New car incoming...
                  • Is anyone available on the Gold Coast to code a highline RVC (swivelling lines) to a RNS315 in a 2014 Amarok Highline?
                    • Originally posted by mrst3ve View Post
                      bump, happy to pay... closest i’ve got is $198 on the Sunshine Coast
                        Did you install the headunit or the RVC?
                        • Originally posted by The_Hawk View Post
                          The headunit already was in the Amarok. I installed the RVC.
                          • It’s been a while, but from memory you won’t get bendy lines since there’s a part in the steering wheel you need too, it also can’t be calibrated outside the factory. I’m questioning that memory a little and maybe they do still turn, but I’m about 80% they don’t.
                            At the very least you can turn it on and make it work as a RVC.
                              I installed this from Euro Car Upgrades - Volkswagen Amarok Ultimate High Line Reversing Camera retrofit VW OEM 2H0907441 2H0980551 - Euro Car Performance & Electronics Upgrades - so should be good to go. I’ll update once it’s coded, no takers yet though.
                                My memory is clearly failing me... a quick google turned up my own thread here:
                                Rearview Camera install (highline)
                                Yes the lines turned in my install so ignore my previous comments and good luck finding someone local to lend a hand getting it coded. Assuming it all works as it should, it's a very quick job.
