Mk1 16v Project
  • I've been pretty bored this weekend.. So after i got sick of scrambling my Rubiks cube and solving it and then seeing what pattern i could create umpteen times....
    I decided it was time to go machine something.. Anything! haha.
    The best choice i came up with was lightening my intermediate shaft.
    I chucked it in the lathe and went to town on it..
    The casting, although quite good, with virtually no mismatch was eccentric but about 1.5mm! Bloody terrible.
    The shaft, between the 2 journals basically tapers from one end to the other. Luckily the smaller end is pretty close to spot on concentric, and then it obviously gets worse as if moves along to the other end.
    What i have done is turned it down to 18.0mm from one end to the other, with 9mm radii in the corners to ensure there is no weak point. 18mm was just enough to clean up the smaller end.
    Obviously, the shaft would still not be perfectly balanced, but it would be more than close enough. Because it runs at half speed, at maximum engine speed, which in my case will hopefully be about 9000rpm or a little less, the intermediate shaft will be doings no more than 4500rpm ever. Also, there is much less rotating mass aswell as a very small diameter. So therefore, balancing is much less critical.
    If anyone else is interested, i can provide these types of services for them, too. (Hows that for blowing my own trumpet.. )
      I reckon you just pulled the sticker's off & swapped them around!
      Top work as alway's Preeny.
      • Originally posted by golfworx View Post
        Hahaha I'll bring it to melbourne and teach you how if you like. Kinda ruins the mystery when you know how though.
        Thanks Tim.
        Oh, and no wise cracks about the Aviators? that surprises me..
          ...Oh, and no wise cracks about the Aviators? that surprises me..
          Actually, when I first saw them, I thought "oh no, Preeny's been milling with the avaitors on again!" and got an image of you with ya tounge out milling away at the shaft with ya shades on!
          hahaha.
          You make me laugh.
          EDIT: I see you've also put the rear visor on too! nice one!
          • Jarred, that aint no mill!!!! thats a lathe
            however as a fellow aviator wearer i couldnt bare to make a wise crack about them hahah
              Haha its held on by the rear wiper at the moment!!
              Hahaha nice. I was going to mention that.
              Ok enough clagging up the thread!
              • When i was back at my previous work i checked the balance of two 8v standard intermediate shafts on a dynamic balancer and just for interest sake they were both under 2 grams of balance at 500rpm. They were just like preeny said....
                But this was done by the factory to offset the cam lobe for the mechanical fuel pump...
                Good work Preen once again! Im currently hunting for a techtonics intermediate shaft pulley if your keen for one that will match your cam gear let me know bro.
                Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
                Mk1 twin eng twin turb
                scirocco gti 2.1l 16v turb 6spd
                Audi A4 B5 1.8t
                • Originally posted by twin eng, twin turbs View Post
                  Ahh makes sense.
                  Yeah if you can find one snap one up for me! My TT cam gear hasn't turned up yet.. Not happy.
                    Ahh makes sense.
                    My cam gear came in under 2 weeks after i paid, it will turn up..... eventually i hope for your sake
                    Audi A4 B5 1.8t
                    • Mmm, nice lathe! Better than the old beast at my work that just ovalised my top mounts!!!!
                      • Originally posted by Valver. View Post
                        ?? nasty! Thats gotta suck!
                        The best thing about my lathe is that its mine and i'm the only one who uses it.
                        • Got my hatch back from Brian Keegan all repaired and the badge holes filled in. (Welded not bog!) Very happy.
                            It's the only way to do it! shaved tails ftw as they say.
                            pity you didn't do it yourself...
                              Considering he's one of the best panel beaters in australia and he did it for free.. Why would i bother!
                              All i had to do was make him a blower pulley adapter for his open wheel car. (its got a windsor in it with a GM 892 on it.. )
                              So yeah yeah rave on again about how mad it must be to have friends like i do...
                                You sure he's not one of the best panel beaters in Orange?
                                mk2 GTi 16v
                                Corrado G60
