Tyre Options
  • plug some figures into the link. 7.5 ET51 has less brake clearance than 8 ET42. Orange profile is original, green is modded.
    eg: when I had 17x8 ET35 they poked outwards too much. In order to bring them under the guards I was going to machine 10mm off the inner wheel face where it mates with the hub. Resulting ET would have been 45. I agree, it makes no sense.
    Edit: If you old rims =18x7.5 ET52 and the new rims = 18x8 ET42 and the design / proportions of the rim were exactly the same then the ET42 rims would have about 3mm extra clearance between the spokes & the brake caliper.
    • Stock brake caliper to spoke clearance should not be an issue at all
      (the stock caliper is all on the other side of the disk rotor)
      It did have problems with my BBK calipers, the Neptunes hit them
      I had another set of wheels that needed a 3mm spacer - sold them
      The Audi RS3 wheels have spokes with good clearance - no spacer needed
      • Well I just ordered my Alzor 349 18*8 ET45. They will be on a slow boat from the USA so I'm not expecting them to land in Brisbane for another 2 mths+.
        Now the wait begins.
        Still deciding on whether to go with the stock tyre sizes (225/40) or go that little bit wider (235/40) to avoid the rim poke past the tyre wall look (which I don't like visually or protective for the rims).
        • Originally posted by Martin View Post
          These are what I've used
          Michelin PS3
          Lovely all round tire, lasts well, great grip in both dry and wet, not very noisy
          When going hard the initial turn in response a little soft
          Goodyear F1A2
          A little more dry grip than the PS3, maybe a little less wet grip than PS3
          Last very well but more noisy than PS3
          When going hard they are simply awesome, brake hard, turn response is excellent, makes your day
          Given the price and performance of these tyres, it's really hard to consider others
          Conti CS3
          Very hard wearing, pretty noisy (gets bad when below 50% tread), they often slam through pot holes
          Need to pump them up pretty hard to get the turn in response I wanted
          Very good level of dry grip - wet was ok also
          The only point where they really shine is the km you get out of them (with good level of grip)
          Generally I would not buy these given the price
          Bridgestone Potenza 040 & 050
          High grip level in the dry, on wet days needed to get them warm first
          Prone to axle tramp on hard launches
          Turn in is good - braking is great
          Price is simply awful
          Maxis M35
          I had these on the wife's Mazda3
          Surprising tyre - does everything ok - lasting well - price was ok
          Hard launch was better than the 040 (no axle tramp)
          Continental Contact MC5
          We got these in a "pay for 3 get 4" deal - they are on the Mazda3
          Surprising tyre - does everything ok - lasting well - price was good
          Well after fitting Goodyear F1A2 to my Occy RS on the weekend and testing them out today, I have to say my axle tramping is all but eliminated and I now have my full first gear back in action thank goodness. It's like night and day between the Goodyears and Conti's when it comes to axle tramping!!!!
          Very happy indeed.
          • Good to hear you're happy with them
            I would have to revise my opinion of the Maxis M35
            My wife is a very gentle driver, hence they are lasting ok for her
            But I'm on good terms with the local tyre shop,
            they don't like selling the M35 due to poor km/life and associated customer dissatisfaction
            They find is easiest to sell them during the pay for three get one free specials
            • I still can't believe the night and day difference. After the mods such as LCAs and dogbone inserts to try and eliminate the axle tramping, the biggest bang for buck in eliminating the axle tramping has by far been the new tyres.
              Rolling resistance seems a little higher on the Goodyears but?
              • Originally posted by donweather View Post
                You got new rims as well. Is the new rim/tyre combo lighter than the old one?
                • Originally posted by brad View Post
                  Yes, but not by a significant amount. Maybe 1-2kgs per corner tops. So 10% lighter say.
                  • 1kg unsprung is worth 2-4kg sprung (depends who you're talking to), so there would be a benefit but good tyres should always be the first mod IMO.
                    • That's quite a saving in unsprung weight as brad said. Would actually make a decent difference even if you had the same tyres, although I suspect tyres made the biggest difference.
                      2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
                      • Our previous 2 Mazdas had axle tramp something chronic. The first got a lot better, and the 2006 Mazda 6 it disappeared altogether with Michelin PS3s compared to the stock Bridgestones which were pretty rubbish.
                        • Originally posted by woofy View Post
                          Turanzas? They lasted forever - every kilometre was hell
                          • I can't recall which ones, the Potenzas or Turanzas, we had the classic not the lux sport one used one, the other the other. They lasted about 60k and we were glad to see them go. The PS3s were awesome, pity we ended up selling the car with hardly any use of them not so long after. Our PE2s on the RS are at 62k with still a decent amount of tread left, those are the opposite, I think they are better than the PS3s and don't want them to go.
                            • I have Potenza RE050A on the car at the momet & for an old tyre they are pretty good.
                              Turanza ER300 (which was one of the available types when I bought the Octavia) seem to be made of steel & with similar grip / wear characteristics.
                                62k from a set of tyres and still more to come....bugger me. I was lucky to get 40,000 from my conti's!!!!
