I'd go for the lightest, good quality rim you can possibly afford. About the only question I'd have on your two choices is what is the manufacture method - forged, high pressure or low pressure die cast or gravity - there are some variations on these types too.
You will notice the 1kg difference between your choices. The biggest mistake I have made on my car is the wheel weights.
235/40 is also a good choice for all the reasons you stated provided it doesn't make your actual speed greater than the indicated speed. Do you have any idea how the speedo reads now? ie 100kph on speedo is ???kph on the GPS. If your discrepancy is like my car then 235/40 will be fine. I have 658mm diameter tyres & 100=100. When I had 632mm tyres 100=90. 235/40r18 will be around 645mm.
A few of my mates would be able to pick a slightly slower turn-in / response from the wider/taller tyre but I doubt I could. Ride might be slightly plusher.
I have no idea about your axle tramp issues - have you put an insert in the dogbone mount yet?
Regarding offset, I had 17x8 ET35 & the rear was perfect but the front was out past the guards. ET42 should be close to perfect up front but even ET45 will have "the look".
What's the ball park money?
Before you pull the trigger, have you looked at TSW wheels? They do a nice line in rotary forged wheels. The weight is similar or less than the cades bern.
