Sad there is no sign of a Diesel wagon with cloth seats. Maybe in the new Scout - I hope so because otherwise I won't be considering a Skoda for my next car...
New Octavia ....when? How Much?
I'm hoping the same for a diesel manual. An Ambition Plus 110TDI would be a good idea to me, and to be honest the 103TSI should be limited to the Ambition. But ah well...Originally posted by iamthestig View PostSad there is no sign of a Diesel wagon with cloth seats. Maybe in the new Scout - I hope so because otherwise I won't be considering a Skoda for my next car...Mine: Silver 2006 Volkswagen Golf Sportline 2.0FSI 6M (with a sunroof)
Parents': Candy White 2008 Skoda Octavia RS 2.0TFSI 6M Liftback
Originally posted by woofy View PostAfter sitting in an Elegance, compared to the last model, I could live with one with a tech pack so will see how the RS turns out. Last time round it was the RS or nothing as the lower models looked pretty basic.
+1
a 132tsi elegance model with the tech pack looks very promising.
it would b nice if the RS is specc'ed up like the elegance model, but i fear it will more likely to be based of the ambition plus, with some additional items made std.MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
I drove the DSG. Still laggy and torque limited in 1st gear. Takes 3 sec to disengage clutches and get going, then gets to 2nd and THEN it takes off... No thanks.Originally posted by dArK5HaD0w View Post+1
No manual in the diesel, and if thats especially true of the vRS then I'll have to look elsewhere for my Manual Diesel Sportwagon. :'(2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
Not including hers...
the only 6-speed dsg available (currently for the oz market) in the new mk3 is mated to the 110TDI.Originally posted by Mysticality View PostI drove the DSG. Still laggy and torque limited in 1st gear. Takes 3 sec to disengage clutches and get going, then gets to 2nd and THEN it takes off... No thanks.
this model features the start-stop technology, which explains the behaviour u experienced. I too found this unpleasant.
drive a DSG-6 without the start-stop technology.........
.....which u unfortunately cannot do atm with the mk3 Octavia.
take a mk2 Octavia mated with a dsg-6 for a spin.
if the mk3 vRS also comes with this stop-start technology, then i'll find every means possible to disable that feature. if it can't b disabled, then, like u, i'll go elsewhere.MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
We must have driven very different cars, the 132 that I drove went like a rocket with only a little bit of lag and certainly nowhere near 3 seconds, less than 0.5 sec I would guess.Originally posted by Mysticality View PostI drove the DSG. Still laggy and torque limited in 1st gear. Takes 3 sec to disengage clutches and get going, then gets to 2nd and THEN it takes off... No thanks.
Having said that the 1.4 was definitely a bit more responsive with the DSG and just seemed to suit the DSG better which is why I chose it. The 7 speed DSG has to be the best auto gearbox that I've driven.
Did a test 0-100 when the other day and ran around 8 secs which was quite surprisingSteve, 2013 Octavia 1.4TSI Elegance wagon
My wife's A1 has start/stop, which is easily disabled (temporarily) by a button on the dash. It re-enables when the ignition is cycled off and on. I think I saw a setting on the MFD somewhere to disable it more permanently, but not 100% sure... I'd assume the new Octy would be the same?
The couple of times I've driven the A1, the start/stop has never bothered me. I also drove a Renault Scenic diesel manual with start/stop around Italy (including Rome) and I was quite impressed at how responsive it was - slip trans into neutral, foot off clutch, engine would stop, as soon as you put any pressure on the clutch pedal the engine would be started and running again almost instantly, well before I had selected first gear. Mind you, it certainly caught me out the first time it operated (frantically trying to re-start the thing)!MY 22 Superb Sportline Wagon. Moon White.
1985 BMW K100RS in JPS racing livery
2019 BMW R1250GS Exclusive
Not sure if it adds stress to the engine. But you'd have to think that manufacturers have sorted that problem out.
I had 2 weeks in a rental diesel BMW using stop/start in Europe (which averaged around 5 litres per 100 even though I thrashed it on the autobahns). I had no problems with the system, it worked flawlessly and would save a bucket load if you live almost anywhere in Sydney where sitting in traffic is the norm. I've also driven in the new Passat bluemotion with DSG and while you can turn stop/start off via a button on the console, the owner said he is very happy with it. I'm surprised that anyone would be against it given the praise for low fuel figures here. I'm guessing that the claimed fuel efficiency of the new Octavia is only achievable if the system is turned on?
Cars with start-stop have upgraded components, like a much higher quality starter engine and whatnot. Starting an engine when its warm doesn't have much of an impact, and the systems have a bunch of criteria that must be met before it lets itself start-stop (engine temp, battery voltage etc.).Originally posted by donweather View PostI was always told that the lost damage one does to an engine (particularly a diesel) is at start up of the ignition. Start-stop technology must be bad for the engine IMO and I'd never use it. What's the cost of a new engine over how much you'd save in fuel with start-stop.
As mentioned before you can at least disable start-stop for each ignition cycle, so I don't see how you can't try out the new 6-speed wet DSG? A better comparison would be the Golf GTI anyway (If you're curious how the RS will be).Last edited by readerr0r; 07-01-2014, 09:05 AM.MY16 Octavia RS 162 Race Blue Combi
It's the cold start rather than starting in general.Originally posted by donweather View PostI was always told that the lost damage one does to an engine (particularly a diesel) is at start up of the ignition. Start-stop technology must be bad for the engine IMO and I'd never use it. What's the cost of a new engine over how much you'd save in fuel with start-stop.
Just sitting idling doesn't do a diesel any good either unless you bring the revs up to 1200rpm to prevent diesel plugging.
Stop/start has a whole heap of parameters that must be met before it comes into play. Engine temp is one of them I believe.carandimage The place where Off-Topic is On-Topic
