I'd done a big post today in the group buy thread in the ice forum about my install experience from the weekend not realising kamold had already posted here.
I have the liftback and the connector is wrong for it too. The one on the car is much smaller than the one on the handle. Mine was fixed with some dodgy soldering onto the pins on the handle and an excessive amount of hot glue to try to hold it all together.
I also found the reverse light wire was only reading about 10.5v. I ran a separate power wire from the fuse box so I could install an accessories socket in the boot since the liftback doesn't come with one so I ended up using this switched by a relay I hooked into the reverse light wire so my picture is mostly stable now but I get a bit of tearing at the top of the image. I'll pick up the Jaycar filter on the weekend and hopefully that will fix it.
I think with my camera it seems like it is slightly angled towards the kerb. Did you find this with yours? Would be nice if it was angled slightly lower so you could see the rear bumper.
					Originally posted by kamold
									View Post
									View Post
