New Forum Server and Software
  • New Forum Server and Software
    We are learning together here, so please be patient. If you have questions, please post them here. If you have worked something out and can provide an answer, Do that too!
    I'll do my best to keep up.
    Current Status:
    • Ads are not back online (for non logged in members) which means zero revenue until I fix that which is a bit of a priority if the forum is to continue. < Work in progress
    • Email notifications including for new sign ups are failing. < This appears to be working now.
    • Signatures seem to work, but the old signature pics seem to be gone.
    • SSL is broken, working on that. <Maybe fixed?​
    • All accounts should be migrated with your same old password and details attached.
    • Private messages have come across.
    • Avatars seem to be hit and miss at best + uploading new ones fails < Seems fixed
    • Access rights should be the same as before.
    • Attachments and images *should* be working.
    • The search index is back online
    • Database has been semi cleaned.
    • Backups are working.
    • Smilies all working again.
    But the good news so far is that even while flogging the database and doing things, the server appears to be holding up very well without crashing or lagging. If anything it feels *too* powerful!
    You can change the theme in the bottom left corner. I might develop something one day, in the interim I will take feedback on the best default option.
    Click image for larger version  Name:	image.png Views:	0 Size:	25.0 KB ID:	2037517
    As a new feature, I PASTED that image from a snip.
    And this one I dragged into the window and it magically added itself!
      I like it!! Very neat and a much closer "look" like other car forums on the electric internet (so easier to learn and navigate the forum features).
      Not sure why "Grunge" was chosen as the default theme - probably because the decision was left to the code-cutter!!
      Does the new forum software permit a signature - can't find it? And what are the file conditions for the avatar?
      Don
        Grunge... what can I say, I'm a certain age But like I said, I'm open to suggestion and have left all the options open for people to choose from but haven't had the time to pick which should be the default.
        Signatures are in there but for some reason were turned off. I've turned them back on globally now (hopefully). Please let me know if that doesn't work.
        For those that want to turn it off (or back on) or modify it:
        Click your username at the upper right corner and then choose User Settings.
        1. Click Account tab
        2. Check "Show Signatures" checkbox.
        3. Click "Edit Post Signature" link.
        4. Type your signature in the editor.
        5. Click Save button.
        6. Click Save Changes button.
        For avatars, I don't know why they aren't working since I did move all the files over but I will have to double check the locations. If you replace it now it will just point at the new file anyway, so have at it! In your profile, just click edit avatar.
        It says "Note: The maximum size of your avatar image is 200 by 200. If your picture (or crop area) is larger, it will be resized to the allowed dimensions.​​" which seems to indicate the system will just work it out.... but I'm having issues with it failing with some system error. Add that to the list of things to fix.
          @the_hawk: Excellent!!
          I notice that you have restored both Signatures and Avatars from the old software. Well done - take $20 out of the Watercooled petty-cash tin (tell the accountant that I said that it is OK)!!
          Just one further suggestion and I'll remain silent - the "YouTube" tile at the end of tile-list is blank (at least it is on my screen). Not a big issue-just bringing it to your attention!
          Again, thanks for the good work.
          Don
            I appreciate the feedback, keep it coming and I'll add that one to the list!
            Signatures are fixed.
            Avatars are "working", but not how I wanted. I might have to settle on that.
            I've noticed that some buttons appear blank but usually it's contextually obvious enough that people should be fine. That Youtube one, I have to assume there is a missing logo file somewhere for that one.
              The_Hawk:OK, at the risk of monopolizing this thread -"keep it coming" I will!!
              Does the new software have an UNDO function - some other car forums have this facility? If so, it is mighty helpful for those that tend to be more verbose in their posts (like someone whose identity I won't disclose)!
              Don
                There is an undo/redo function while writing a response and mods can see things that have been edited. Not sure what you mean otherwise.
                Edit: That youtube button seems to be broken, I suspect a hold over from the old forums. I'll have to look into that.
                Edit 2: Deleted broken Youtube button. I suspect old posts with that old tag/code might be broken.
                There is a video tag button which does this:
                Without tags: https://www.youtube.com/watch?v=Xn2rJxTlomY
                With Tags:
                  Thanks Hawk
                    Email notifications should be working as of this morning. Note things are coming from a different domain (.com rather than .com.au now) so update any rules/filters you might have had active.
                      Great work Aaron!
                      It's never fun doing all the hard work for a migration but we all appreciate the time and effort you've put into the site over the years.
                        Today I fixed the Smilies (of which there are hundreds!)
                          It looks like the google ads are coming back online. The way this works is that guests see ads, anyone logged in shouldn't see those ads.
                          That said, while I'm tinkering and testing I have left a single ad turned on for logged in users down the very bottom of the page. Please let me know if this causes any issues (or if ads are displaying anywhere else).
                            I cant find a "mark all read" option like existed previously and exits on many of the car forums I visit. I find it useful to scan and read the posts of interest and then mark all the remaining read.
                            2013 Touareg V8 TDI R line and spanner on my sons Mk4 R32
                              At the bottom of each section (or "Channel") there is a way to make the whole channel read.
                              And on the main forum page there is this right down the bottom:
                              Hopefully one of those helps you out.
