Copper sump plug crush washers
  • Copper sump plug crush washers
    I have replaced the standard sump plug in my MkV GTI (I believe most VAGs use the same sump plug) with a Magnetic sump plug.
    Can someone confirm if there are any issues using a copper sump plug crush washer. I think the original looks like steel (washer and bolt is disposed each time).
    Also is the size Aluminum Drain Plug Washer M14x20?
    MY07 Red GTI 3 Door
    My car's original sump plug installed in the factory was aluminium with an aluminium washer. The dealers always replace these at every service with a new steel plug with a captive steel washer. I was annoyed they threw mine away as it only needed a new washer and could have been used indefinitely. I never felt comfortable that the steel plug used by VW was made of a harder material than the sump.
    I too installed a magnetic plug (from ECS Tuning) that was supposed to come with 10 copper washers. I determined the 10 washers I received are actually brass - too hard in my opinion. So I bought a number of aluminium washers - sorry don't know the size.
    My own opinion on washers is:
    aluminium - best
    copper - OK
    brass - no
    steel - no way
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
      They're 14mm ID.
      You can pick up bulk lots of them on Ebay for stuff-all.
      '07 Transporter 1.9 TDI
      '01 Beetle 2.0
        Yeah going to order from eBay, just wanted to confirm the size (14mm).
        aluminium - best
        copper - OK
        brass - no
        steel - no way
        I'm not sure why they use a steel plug and washer, and then replace both of them. I'd too be upset they if replaced an aluminium plug with a steel one.
        You can pick up what looks to be a aluminium plug with magnetic tip for a few dollars on ebay.
        I too have the ECS plug. I lost the 10 washers so am looking for replacements. You may be correct, they did look hard so was replaced by an aluminum washer.
        I think the plug was over tightened so I can't even get the washer off the plug! Thank god the sump plug hole wasn't damaged.
        Sent from my SM-G930F using Tapatalk
        MY07 Red GTI 3 Door
          The washer on the OEM plug is captive.
          Over several uses, the washer becomes thinner, the plug distorts, and eventually trashes the thread in the sump.
          As cheap $4.50 insurance, dealership practice, is to replace the whole thing each time. Much cheaper than replacing or repairing a sump.
          '01 Beetle 2.0
            Be careful mixing and matching metal alloys, some combinations can cause electrolytic reactions. Just ask the owner of an aluminium dinghy what happens if a fishing tackle swivel remains undetected on the floor...
            2015 Jetta Highline
            2017 Ducati Supersport S
              I had a magnetic sump plug and washers from ECS Tuning, but found that i always had oil leaking out. Swapped back to the OEM sump plug and no more leaks.
              B9 Audi SQ5
                Thats because at some stage the plug was overtightened ! Once its overtightened once they start to leak , the more overtightened the worse the leak is . My own Golf R which has 90k kms and oil changed every 5k kms is bone dry .
                  Ahh fair point. I had one on my old Golf R and never had an issue, but it leaked on my GTI....i have now reverted back to OEM plug and its all good again. Never crossed my mind that it may have been damaged from over-tightening.
                  B9 Audi SQ5
                    On the GTI with the tin sump, there's a specific plug and separate washer for them. Those, you can just replace the washer on it's own.
                    If you use the regular plug with the captive washer on them, it'll leak.
                    '01 Beetle 2.0
                      And now, we have the plastic sump with a plastic plug (rubber washer).
                      MK6 MY10 Golf GTI, 5dr Manual, Carbon Steel, Detroits, Tint
                      T6 MY06 Peugeot 307 HDi Touring, Manual, Iron Grey, Tint
                        A solution to a non existent problem. Good thing plastic sumps are more durable :O
                        Although I see the benefits of a metal sump with plastic plug.
                        My old car had a rubber washer (metal plug), IMO better than crush washer.
                        MY07 Red GTI 3 Door
                          I happened to have my washers out, so I thought I'd check the sizing on a selection of various different ones.
                          They all seem to have an ID of 14.4mm and an OD of 19.9mm. That should a guide for you Johnbu when buying more.
                          Recently I bought some aluminium ones from a Euro service specialist in Richmond (Melbourne).
                            Thanks, good to know.
                            Which place was it and how much did they charge you? I may pick it up rather than ordering them online if not too expensive.
                            MY07 Red GTI 3 Door
                              PM sent
