self destructed
  • self destructed
    Set off with friends for a trip through western Qld. Had my T4 diesel serviced including the replacement timing gear. Having travelled 6000k and almost reaching Mooloolaba on the way home, the motor just ceased to function. Not seized, just no compression on any cylinder. I just hope that it is covered by the service centres waranty. Probable timing belt slipped and taken out the valves, possible rockers, possible pistons. NRMA having it returned to Sydney..and then the fun starts. Jim
    Last time I did one, the pistons were fine, but it destroyed the head.
    Cracked the combustion chambers where the glow plug threads are, and smashed all the lifter buckets and shims.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      Thanks. Hopefully that is all that is wrong with mine
        Had the same thing happen on a Land Rover Discovery 1.
        When they replaced the timing belt they didn't tighten a retainer on the tensioning device. It slipped...
        2015 Jetta Highline
        2017 Ducati Supersport S
          I will be following this thread with interest. While I have never had any form of pileup,I follow the threads on the T4 Forum. I have changed the belts on the two T4s I have owned & still own. This maintenance procedure requires careful work after considerable research.
          Unfortunately there are too many mechanics that don't have the necessary experience/knowledge & special tools.
          Numerous Mk1 Golf diesels
            I understand that the water pump should be replaced at the same time. This was not done. I think it might be time for a new service centre.
              Yeah, it's just another thing to go wrong and cause the belt to fail if not changed.
              Last one of these I did, the previous mechanic left the old pump on it, the bearing it failed, skewed the gear, causing the belt to wear away on the belt cover. I managed to catch it when the belt was ¾ of an inch wide still.
              '01 Beetle 2.0
                Car now with repairers. Timing gear intact. What else could cause a sudden loss of power and loss of all compression?
                  The spanner they left inside it?
                    When I left he was about to check timing to see if anything slipped. Next was to remove rocker cover. Haven"t heard from him today
                      Sounds more like a stripped spitzl bolt thread in the flux capacitor........ Possibly the quadrionic plasma condenser got taken out too.
                      1981 Honda Civic hatch. Proper AUTO REVERSE cassette player. AM/FM with Stereo speakers. Four (yep, FOUR!) speed manual. Full cloth trim seats. HALOGEN lightbulbs! Factory options fitted: rear wipers and washer, "Go Fast" wheel covers & electric front windows.
                        Followup is that timing appears to be correct but compression test showed no compression on any cylinder. This has got him confused so at the moment they are about to remove the head to have a look inside motor
                          Does the car happen to be in Darwin or Alice Springs? They seem very slow to do anything, they should have known by the next day really.
                            Took him 2 hours to check timing belt. Car sat for 5 days before he touched it again
                              Motor destroyed. Dropped a valve and bits all through motor. Block damaged beyond repair. Anyone know of a replacement motor? 2.5l diesel.
