VW T5.1 excessive oil use
  • #31
Name:	EGR D Cooler Corroded.jpg
ID:	1826543Click image for larger version
Name:	EGR Cooler Corroded 2.jpg
ID:	1826544Click image for larger version
Name:	EGR D Cooler.jpg
    2014 T5 132Kw Twin Turbo, 2016 "D" Suffix EGR Cooler, 4 Motion, 7Spd DSG + Diff Lock, Frontline Camper.
    • #32
      Hey Craig,
      You should be fine with your as didn't they fix the issue for 2012 onwards?
      And you have (D) suffix, so does that mean yours is not affected?
      I finally see my new van late next week, so i'll get to see what my engine code is as mines still the 132kw Bi-turbo Euro 5..
      2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
      • #33
        Originally posted by Bryn23 View Post
        Hey Craig,
        Only time will tell that they have fixed it with the "D" suffix. An EGR with a "C" suffix still suffers the same problem.
        • #34
          This is an interesting read , the old subject of bigger cubes being better than small engines The age of smaller engines may be over
          • #35
            Every one with 1/2 the brain ishould be able to figure out that with the current technology what is available, that the smaller engine has to work harder and will wear out much sooner.
            • #36
              Is it really working harder, or have the boffins found ways through technology to achieve performance figures more effeciently?
              • #37
                Seems fine with the single turbo!
                2018 Crafter Runner
                2012 T5.1 6sp manual.
                2024 Crafter Auto
                • #38
                  Likewise with old-tech 1.9!
                  • #39
                    I am not so sure if you work out the engines ability and the load to carry logic dictates that a smaller engine even with Turbos will be placed under more duress when loaded up with goods etc . I know from having my 97 T4 2.5 petrol back to back with my current 2005 T5 2.0 petrol the pulling power and performance is like chalk and cheese . T4 would eat the T5 for lunch and spit it out easily . T4 specs 115*PS (85*kW; 113*bhp) @ 4,500
                    200*N·m (148*lbf·ft) @ 2,200
                    1997–2003
                    T5
                    116*PS (85*kW; 114*hp)
                    170*N·m (125*lb·ft)
                    So the 2.0 has 30nm less torque but same 85 KW output so why does the 2.0 struggle against the T4 , My sons T4 now sold when I did a comparison walked all over my T5 .
                    • #40
                      That extra 30Nm can move a lighter bus much more easily.
                      • #41
                        I noticed that the just announced New D Max has gotten a larger 3 litre Turbo Diesel instead of the smaller 2.5 Litre for the Europeans.
                        The old engines were 2.8 litre if i recall so it is a small increase, but heading the right way.
                        I do think, that the tech guys are quite amazing to get the amount of power out of the smaller diesels, but i think that durability is sacrificed in the process, regardless of the materials used, pressure brings out any failures within the material, sooner than later.
                        Less stress = longer life, well in theory
                        Be nice to see a small V6 turbo diesel 3 litre framed in that front end of the Transporter.
                        • #42
                          Well they had a V6 petrol one in the T4 but probably due to the surge in diesel popularity at the time it was dropped , I do believe it was a bit thirsty on fuel .
                          • #43
                            Not emissions friendly, either.
                            • #44
                              V6 Petrols do like a drink around town and when loaded
                              • #45
                                The dealership just sent me my engine number it is a CFC engine then followed by numbers, i thought it would be a CFA motor, but it doesn't say what version.
                                Where do you find out that Info?
                                I pick it up on Tuesday after a process lasting almost 7-8 months.
                                But to an ordering issue, which wasn't my fault, the lift for the van won't be here for another 2 months
                                So i have a perfectly good van sitting in the carpark for 2 months until I can use it
