Sounds like a major head gasket failure. Keep us updated mate.
VW T5.1 excessive oil use
 I suppose the water could be from a degrease as someone may have gotten a bit over the top with a gurney , the oil dropping that much is a concern . There could be a couple of reasons bad rings blowby from the turbo , if there was an issue with water getting into the engine itself then I would imagine the oil on the dipstick would show that or at worse an increase in level as it would mix partiually with the oil . But telling would be if it was water getting into the engine you would see a drop in the water cannister level. When our water pump went it would use a litre of water every 100 km's or so .
 I had to recently replace a crappy little water junction with a temp sender bolted onto the head.
 Had to remove a lot of stuff to get to it.
 When I got it off, it looked like they at 'nicked' the seal on installation at the factory.
 Lasted over 300kms though!
 Number 3 in this diagram.
 The culprit....
 At the back there's a special, orange O ring/seal that VW sell.............but the whole unit with the sender was under $100 and the amount of work to get to it, it was best to replace the whole thing.
 This might not be your problem but it took about three weeks before the leak became prominent enough to see where it was coming from.
 That said, I do over 300KMS a day so on casual driving, it may well take longer.
 (no oil problems though)
 edit - this is a CAAC engine.2018 Crafter Runner
 2012 T5.1 6sp manual.
 2024 Crafter Auto
 So i got a quote from VW....I also noticed a rattling from the flywheel which sounded like it had marbles in it.
 I called VW who quoted.
 Engine and Gaskets $7113
 Flywheel $1742
 Oil $130
 Labour $3050
 Total $12035
 (But i wouldn't get a 2 year warranty on the motor)
 To get a 2 year warranty, i also need...
 $1435 Cat Convertor
 $1782 DPF
 $110 Sleeve and Clamp
 $426 o2 Sensor.
 So total is $15,788
 Park it on a steep hill like I did even with the handbrake on and in gear it still rolled down our hill , luckily it went very slowly against the compression or lack thereof and finally came to rest against another car and power pole . Insurance fixed both cars and mine got a full repaint from door to door and it was 12 years old at the time !! Now you didn,t hear that from me or on this Forum , but food for thought or wait untill the next big hailstorm .
 it would be interesting to see a third party quote, if you do get one, can you post the prices?
 i'd be rebuilding the engine without the DPF.
 its just plain stupid pricing from VW, when its their DPF design that is causing the issues.2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
 VW Australia have refused assistance due to age. I will be escalating it, contacting consumer affairs and pursuing this at the highest levels. We have been failed by VW since they recognise the engine is failing prematurely but are hoping for it to happen out of warranty.
 My EGR was the suffix 'A' model. You can find it by looking directly below your bonnet catch for a metal plate with a sticker on it. The letter on the end is the suffix. The only one that doesn't break down prematurely is suffix 'D'
