Height of Jacking points
  • Height of Jacking points
    Hey All,
    I've ordered the 3200GVM LWB Special Order and with these models you don't get a spare or jack, just a can of tire repair.
    So I'm getting a Spare Tire to fit once its arrived, and i also need to get a Bottle Jack, so I'm not relying on a repair spray can out while I'm campervaning
    What height do you guys have on a standard model from ground to jack loading point...
    So i can work out what bottle jack height that will work.
    (I should note, that a standard VW transporter scissor jack for some reason isn't meant to be used on the T32 / 3200 GVM models... i don't know why, its just seems to be highlighted on the VW OEM scissor jacks)
    Thanks for your help in advance.
    Cheers.
    2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
    Just did a quick measure to the outside of the sill panel and mine comes in at 300mm front and rear.
    2012 T5 LWB 4Motion LIFTED
      I would buy a bottle jack with the adjustable centre , I bought a cheapie from Super Cheap when I did our front suspension and some other jobs worked a treat , check the weight limit before to ensure safe operation .
        Thanks guys, that measurement helps.
        I was looking at an adjustable centre, its handy for fine adjustment.
          my 04 with 235/55x17" is around 240mm front and 270mm rear, clearance to jack points
          min jack height to get the jack under the vehicle is roughly clearance minus tyre sidewall
          min jack height to lift tyre off the ground around 340mm front, 350mm rear
          Steve
          04 T5
            Thanks,
            I'm looking at a Kincrome 8 ton model, min is 238mm and a max of 478mm
            https://www.kincrome.com.au/bottle-jack-8000kghttps://www.kincrome.com.au/bottle-jack-8000kg
            Im looking at the Seikel Maxi lift so that'll add 30mm to those measurements.
            You can get a Seikel bottle jack, it lifts to 700mm..... i wouldn't personally trust a bottle jack at that height... nor could i justify the cost of the Seikel Bottle jack... its crazy money in euros, hate to see what its costing here.
              Originally posted by Bryn23 View Post
              Thanks,
              so , that jack may not fit under your vehicle with a flat tyre.
              With mine the tyre sidewall is around 100mm, so flat clearance is theoretically around 140mm or slightly better, haven't actually measured it flat.
              Steve
              04 T5
                Crap how did i not think of that
                  Maybe keep or get an original VW scissor jack to get the van up high enough for the bottle jack to take over ,cheap enough at a wreckers .
                    Hi Bryn23
                    How did you know you could order the uprated GMV, I couldn't find the option in the current spec sheet VWCTRANBROMY16.5?
                      Originally posted by Tornado T5 View Post
                      Hi Bryn23
                      Well i knew that Trakka and the Ambo's got them into Australia, So i knew the 3200 GVM had been compiled for ADR already.
                      It was just a case of hassling VWA about it, as the dealers told me it couldn't be done as it isn't on there dealership ordering system, the 3200GVM codes aren't on the system, they have to get the vehicle code of VWA.
                      Once i had a email from VWA, saying it could be special ordered, thats when i hit up the dealer and then it was just a matter of them getting a price from VWA.
                      You won't find anything in the Spec sheets as it is a special order, lead time for a 3200GVM can be from 4-9 Months.
                        not a bad idea, I'm going to keep looking as there will be a jack some where that will be perfect, got plenty of time until it arrives in Aus.
                        if not ill go with the two jack option if i can't find anything.
                          Thx...now if only they had a code for a Tdi450, DSG, Crewvan, 4motion, LWB
                          If not a hassle could you pass on the GMV 3200 code please?
                            ...also allow a bit more clearance, since the road is not always straight and flat. Look for the 2 or 3 stage bottle jack, they're compact and allow much higher lift. Put a few wooden blocks as a spacers between the body and also under the jack when you use it.
                            I haven't seen the Seikel jack, but unless it's hundreds of $, I'd buy one, for most people, it's lifetime purchase and can be moved from vehicle to vehicle.
                            Performance Tunes from $850
                            Wrecking RS OCTAVIA 2 Link
                              The Seikel jacks are 189 euro, so around 400-500 to get it here, I'm just inclined to find something cheaper.
                              Wooden block are gold out there, they have come in handy before.
