So, it's with a very angry and sad heart that my first post on here is about my Multivan engine exploding.
Story is my wife was returning from a weekend away, driving up the M5. Engine hot light came on, she slowed down, and pulled over, turned it off. She waited a short while, and tried to fill the radiator with water - it simply ran out the bottom. NRMA attended and towed the vehicle to a local garage - he noted a radiator hose had come off obviously, but also noted on starting the engine that it immediately compressed the fluid. Engine turned off and shipped to VW.
We are the second owner, van is 5.5 years old and has covered 178k km. It was originally from Melbourne and has had a full main dealer service history with VW from day dot until it arrived interstate - and even though it wasn't due a service, I had a full fluid service done just to make sure - all with approved audi/vw fluids. Prime reason for high mileage is the Geelong to Melb trip that it did twice a day.
I would add ... since the day we acquired it a year ago, it has run perfectly, without a hint of loss of power, has never overheated or show any signs of impending implosions.
NOW THE SHOCKER ... VW have come back and said the head gasket has failed, which has warped the heads and a piston has scored the block. New Engine required ... and the kicker ... $12k for a new engine and $4.5k for labour.
I have told them to submit a goodwill claim, and that that is simply unacceptable from a "Fit For Purpose" perspective. My next port of call after VW will be ACCC and social media. It's unacceptable for a full dealer service vehicle barely halfway through its life to completely fail.
I drilled them about the water pump (they didn't seem to want to answer the question) and whether it was working, which I was advised from the previous mechanic looked like it WASN'T actually pumping water around (i.e. impellors destroyed). I asked VW how often the water pump is supposed to be replaced? They said it's not in the service schedule.
They are telling me the head gasket is the cause of the failure. In my experience, a head gasket is only a symptom of another problem ... and I've never heard of a head gasket failure being instantaneous and fatal.
Clearly ... my first experience with VW ... and an extremely unhappy one right now.
Advice, thoughts, recommendations, prior similar experiences ...??
All thoughts welcome ... I am exceedingly stressed and unhappy right now.
