Howdy, I'm looking to replace the bulbs inside my Multivan with LEDs. Is there any tricks/tips to remove the light covers without damaging them? Cheers.
Tips to remove interior lights re bulb replacement?
Led's installed.
Managed to install the LED's in the interior over the weekend. Tonight was the first time I've driven in the dark. Crikey they are BRIGHT.
Reminded me of the "ugly" lights that used to come on in the pub when it was kick out time.
Nil damage to the light fittings but I did need to remove the front map light fitting to get access there. All in all a good job.
Now all I need is to find out how to remove the footwell "Multivan" lights to change the bulbs there. They look really yellow now when compared to the others. Cheers.
Yes makes you wonder why they still fit outdated bulbs , LED's are so much brighter and less battery drain . I also have fitted a Cree led light bar into the grill and WOW the difference is night and day . High beam means you can see stuff hundreds of metres away .
Sorry for late reply been on holidays and a tablet is a pisser to use to find links so back home and here you go .http://www.vwwatercooled.com/forums/...cree+light+bar
