T5 Using oil
  • T5 Using oil
    Just wondering if anyone has any thoughts on this.
    I had my 3 yr service done 3 wks ago on my 2011 highline multivan, bought new and has always been serviced at the dealer it was bought from.
    Las week we drove interstate on a 2000k round trip. Last night went to take the kids somewhere local and as I started it on came the check oil level alert. I checked the dipstick and it's dry.
    Does this sound normal?
    In the last 3 yrs we have done similar trips and have never needed to top up the oil
    Dave
    Not sure if it's relevant but from some reports 1 litre per 1000 kays is acceptable according to VW , seems a bit sus to me . Any engine that use that much oil must have something wrong . Jeez my old work bus has 253000 kays on the clock and its a lowly 2.0 litre petrol but does not use any where near that much lucky if it needs 1 litre after around 4000 kays travelled .
      Just keep an eye on it mate and report back. Could have an oil leak or not been topped up appropriately at service...
        unless you know the oil level at service time 3 weeks ago, I'd just top up ,then keep an eye on it.
        Actually I'd let the VW service know first, and see what they say.Could be their stuffup.
        Check for leaks underneath? Sump plug tight?Oil filter tight?
        Could be turbo, you can remove the large intake pipe near the EGR and check for oil in the intake, pre and post EGR if you're keen(lever up the large clip then pull the pipe off).Some oil film is normal AFAIK, due to the PCV valve
        Steve
        04 T5
          Cheers for your suggestions
          I took it back to the dealer that serviced it again and they topped it up. Apparently 450ml, according to them that's all it takes to be off the dipstick.
