Originally posted by Umai Naa!!
View Post
T5 2.5 diesel exhaust manifold leaks
My second manifold has failed. the foirst at 139000, 2nd at 243000. had a chat with Frank, the local Sportsvan guy. The first thing he did was look under the van to see if the bottom engine cover was in place. He says that this forces air coming in through the radiator over the top of the engine and assists in colling the turbo. They crack if the covers are removed. Could be, but mine has been on for almost the entire life of the bus.
Fighting with VWSA that says its the age of the bus, and will mot consider my claim.2006 T5 4Motion 128kW Seikel Dakar
At that mileage it's bit hard to push. But you never know, good on you for trying.Originally posted by parafanaylya View PostMy second manifold has failed. the foirst at 139000, 2nd at 243000. had a chat with Frank, the local Sportsvan guy. The first thing he did was look under the van to see if the bottom engine cover was in place. He says that this forces air coming in through the radiator over the top of the engine and assists in colling the turbo. They crack if the covers are removed. Could be, but mine has been on for almost the entire life of the bus.
How much did they quoted you?
Sent from my GT-N7000 using Tapatalk 2Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Sunny43.5 View PostWhilst the price of freight would need to be added this English crowd do a special hand built manifold for the T5 for around $510 PPTuning - your one-stop Performance Exhaust & ECU Chip store - Products Page
Have you or do you know anyone who may have fitted any of these manifolds?2006 T5 4Motion 128kW Seikel Dakar
No. It's a similar clip that fits onto the turbo boost pipe outlet ie 3 pipes before the intercooler inlet. The clips wear against the securing lugs. The clips need replacement before the lugs wear to a point that the pipes are unable to be secured.
Clip 14A
I am hoping thats my problem as well and not a cracked manifold
I can move the large rubber pipe that goes over the rocker cover towards the rear and to the turbo?
Its fairly loose but connected and the underneath is covered in a soot type deposit!
Does this mean it might be the clip??!
