T5 2.5 diesel exhaust manifold leaks
    Originally posted by Umai Naa!! View Post
    Cracked manifolds are common on many cars. Commodores, Falcons, Tritons, Pajeros, Corollas, Elantras, X-Trails, and many more.
    However, nobody ever jumps up and down like a VW owner does.
    I agree.
      My second manifold has failed. the foirst at 139000, 2nd at 243000. had a chat with Frank, the local Sportsvan guy. The first thing he did was look under the van to see if the bottom engine cover was in place. He says that this forces air coming in through the radiator over the top of the engine and assists in colling the turbo. They crack if the covers are removed. Could be, but mine has been on for almost the entire life of the bus.
      Fighting with VWSA that says its the age of the bus, and will mot consider my claim.
      2006 T5 4Motion 128kW Seikel Dakar
        At that mileage it's bit hard to push. But you never know, good on you for trying.
        How much did they quoted you?
        Sent from my GT-N7000 using Tapatalk 2
          Originally posted by Sunny43.5 View Post
          Whilst the price of freight would need to be added this English crowd do a special hand built manifold for the T5 for around $510 PPTuning - your one-stop Performance Exhaust & ECU Chip store - Products Page
          Have you or do you know anyone who may have fitted any of these manifolds?
            Sorry no , I only did some research some time last year I did not require one so I just posted the link .
              I think it is time for me to pull mine of an have it welded up. It is a bit smokey on the cold mornings around the front of the car.
                And before the turbo falls off
                M
                  Long trip next week. 3000km. Don't want issues.
                  VWSA will not budge.
                  Dealer doing job for discounted price. Manifold loose R6800. Fitted with gaskets etc R6200. Big saving.
                  4S TT
                    I can breathe. I went for a second opinion. Turns out to be the boost pipe clip on turbo outlet. About AUD1! phew
                      Are you meaning the clip that holds the intercooler pipe to the housing as ours failed several times and a new one would not have worked as the alloy part it clips to wears so we screwed ours into place has never come off again .
                        No. It's a similar clip that fits onto the turbo boost pipe outlet ie 3 pipes before the intercooler inlet. The clips wear against the securing lugs. The clips need replacement before the lugs wear to a point that the pipes are unable to be secured.
                        Clip 14A
                        • #27
                          Okay ours was the one to the right hand side of the picture but its almost the exact same type its the one at the top of part no 10
                          • #28
                            They are all similar. 3 sizes. Those on the right are cooler charge air leading from the IC to the throttle body and inlet manifold. Top left are filtered air to turbo inlet.
                            • #29
                              I am hoping thats my problem as well and not a cracked manifold
                              I can move the large rubber pipe that goes over the rocker cover towards the rear and to the turbo?
                              Its fairly loose but connected and the underneath is covered in a soot type deposit!
                              Does this mean it might be the clip??!
                              • #30
                                Sounds like it'll be the manifold.
                                If the pipes were leaking, it'd be oil.
