HI all.
My van had a leak around the turbo manifold area . My mechanic removed the manifold and found the flange which attaches to the turbo had broken away from the manifold.There was also a crack starting on the drivers side flange .This manifold is a fabricated item not cast as they usually are .My Question is? is anyone familiar with this problem .I'm reluctant to replace this manifold with another original item as the quality is not up to standard .Does anyone make a more robust manifold? My van only has 110K's on it so at $1100 for the manifold alone plus the labour, it could prove very expensive every couple of years replacing it.I hope someone can give me some guidance on this subject.
regards
Reggie49
regards
Reggie49
