Roof lining join strip clips
  • Roof lining join strip clips
    Hi all, looking for some replacement clips for the joining strip between the roof linings in my T5.1 Transporter … they have a square based pin to slide into the strip and then a grommet in the roof support beam. I can’t tell if it is the pin or the grommet that is failing but this strip keeps falling out at the moment. Will try to load some photos later to help describe the issue.
    Grateful for any ideas other than screwing through the trim strip to keep the damn thing in place.
    VaughnR @ Canberra
    2012 T5.1 LWB Transporter - Stealth Camper.
    Originally posted by Sunny43.5 View Post
    Are these the ones ?
    Yep, them is the ones. When I looked last week JustKampers had nil stock but now have four … but at $4 per clip plus $10 delivery I might wait till they have more in stock and I can get all seven that i need to replace the ones that look broken (or all 12 might be a better option).
    All other sources are on selling UK product, and in turn the UK stores are selling Made in China items. I will keep hunting AliBaba and see if I can cut out some unnecessary travel for my replacement clips
    VaughnR @ Canberra
      Ok check these out packs of 10 or 20 https://www.aliexpress.com/item/1005...martRedirect=y. As I spend a fair bit of time chasing up sunroof parts I find the best way to find better prices is to get the original factory part number put that number into aGoogle search with the letters VW after and bingo lots of options come up.
