Headlight wiring insulation disintegrating - new loom?
  • Headlight wiring insulation disintegrating - new loom?
    My headlight wiring insulation is failing. It 's affecting the wiring in the actual headlight itself. Apparently this is a thing. WTF?
    Noticed it after a bulb blew. Off course it comes just after I spent a few hours polishing the discolored lenses.....and ordering new bulbs...
    Anyway, is there a replacement loom available for inside the headlight?
    For a 2006 Multivan.
    If it is the same as a touareg the answer is NO. I even contacted the manufacturer in France and found they were less than helpful and would not even give me the name of the company that supplied the connectors, so I am doing the harness myself in milspec high temp wire.
      What do the connectors look like? TE makes most automotive stuff. It can be hard to find the part numbers, but I have found suppliers, even for the large 50+ pin RVC connectors.
      TXL cable would be good for that application, rated for high temp and it is pretty thin, TXL AUTOMOTIVE PRIMARY COPPER WIRE
        The connector is the white one in the rear of the headlight housing, it is very brittle and almost impossible to remove. I drilled a hole in the side of the housing but even then the locking tabs broke off. Looked for hours on the net but could not find them.
