Guess its no surprise to T4 owners that the exhaust manifolds crack - It was obvious that the exhaust was leaking from the roar when I purchased the the van - once the clutch was fixed I have moved on to the exhaust repair before I hit the road - well off came the fuel injection stuff to get to the manifold from above - one stripped torx bolt on the back of the engine later ( removed using the fabulous Irwin stripped nut - socket - removal tool - pick the nearest size and tap it down over the nut, apply pressure and undo - the spiral design and sharp fins inside the socket bite into the torx head and undid it first crack ) Every tool kit needs a set !!! Best $59 Ive ever spent cos it saved removing the engine !
Will replace all the torx bolts as they have been a bit abused by others before me.
Off with all the exhaust manifold bolts once the crc took hold ...
out with the manifold !! - tight fit !!
The manifold has been out before and welded - the leak is because the weld has cracked - the previous person sleeved the pipe but failed to weld one side enough - it was done about 7 years ago according to the paperwork so perhaps its worth just patching it up again??
I'll see if I can find a replacement first so a shout out to anyone that has one for sale at a reasonable price or knows where I can locate one - I'm in Tas but guess its going to be a look a bit further afield ...
I was told that the cracked pipe repair was over a bellows that accounted for expansion and contraction in the pipe but the parts manual doesn't show that - I think that perhaps the later manifolds had the bellows setup from the pic's I have seen.
Does anyone know for sure if the bellows setup was standard on the all the T4's or only the later models and do any of the late model manifolds bolt straight on ???
I am also chasing a single exhaust gasket - I got a set of 4 cos they multi fit passat etc but need 5 anyone got 1 for sale ??
Well off in search of a replacement ...
Guess this maybe as difficult as removing a gearbox !!!
