I do have a couple of questions for people.
1) Greasing the slide pins.
I'm realising today that I might need to go back again
a) The front pins come out completly so I did clean them down and re-grease using a high temp bearing grease. This is what a guy in AutoBarn provided when I explained what I was doing, although I'm now reading this might have been a poor choice and something which should be fixed up before it causes binding. Is this something I should go back and re-do. If so what is the recommended grease and where do I get it?
b) The rear meachnism came apart without (from what I could see) breaking any the rubber seals so I didn't tear them apart to re-grease. Is this something I should go back and do?
At least these fixes should be much simpler than the whole job, even if it's a pain to go back (after a good gurney for sure
2) When taking the front brakes apart the caliper was tight enough that I couldn't remove it from the pads/rotor, I'm sure the small lip didn't help either. This appears to be mostly because the pads had stuck to the capiler mechanism.
Is this just a matter of using a little more gentle persuasion? (ie a mallet) Or is there some trick to getting the pads to come away and/or to release the piston a little to pull it apart?
In the video in the first post at about 2 minutes you see the mechanic release the slider pins then pull the assembly up and away. For me that just didn't want to happen because the outside pad was stuck hard to the assembly. A little gentle hammering didn't help but undoing the last two bolts to release the other part of the caliper made it all come away (albeit with a little effort) and once free of the rotor it came apart pretty easily. Now something you would want to do when just changing the pads.
The rears came apart without any issues.
edit: To answer my own Q2, this video appears to show a little levering is the answer, I don't know if that would have been my answer... maybe I find out next time around.
YouTube
).2) When taking the front brakes apart the caliper was tight enough that I couldn't remove it from the pads/rotor, I'm sure the small lip didn't help either. This appears to be mostly because the pads had stuck to the capiler mechanism.
YouTube
