For some reason my T4 2.5 petrol has developed an intermittent fault - when driving in the first five minutes from startup it will occasionally and without warning drop power. If I'm going at a little speed you feel this by the sudden jerk of deceleration, which can be quite violent and shove you into the belts at worst. The engine keeps running after the jerk - it might happen 2-3 times and then the rest of the journey is fine. It happens regardless of throttle angle. At othertimes I have had the clutch in when it happens and the engine dies - easy to restart, most of the time. It happens when the car is running on lpg or on petrol. It happens even if the car is warm from the previous run.
Any ideas what this might be: coil fault?
