So the Multivan key spun around and around the other day (so says the wife), apparently some helpful dad at kinder jiggled it until it clicked back into place and has kept on working without issue.
After being given a $700+ quote to have it repaired I looked up the parts in ETKA and figured it looked easy enough to swap out and I really do miss tinkering with things.
Part no: 6R0 905 851 *
I did read that the ‘B’ variant was replaced in 2010 but when I stumbled across a B for about $60 delivered for a rebuilt unit I figured it was worth a gamble. As it turns out the current one is a ‘F’ version… so I’m going backwards.
Getting the old one out was pretty straight forward, I had everything but the M12 spline drive socket for the steering wheel (which I now have). Getting out the shear bolts was easy enough (I grabbed a set of bolts to use when re-installing).
So the part was removed and I noticed the reco part doesn’t have the solenoid looking part the one in the van has.
Part:
Solendoid?
I had a few thoughts, one was to just put it back in but it seems to have bound up completely after being removed and no amount of tinkering saw it come good.
Plan B: rebuild the old one with all the reco parts. Seems that the electronic ignition bit is not removable, even after stripping the insides from the reco one… also I couldn’t get all the parts out of the original one.
In the end I put the new reco one back together and have put that in. I did have an extra part when I was finished rebuilding it. There appears to be a small locking pin inside the mechanism…. I’m not sure what it does (either locking something open or closed?) but it appears to work just fine without it in there.
The circled one is the one I pulled from the reco part, the other one has mysteriously appeared (even though I never got that deep on the original one…
Extra Pins:
In any case, it’s halfway back in, seems to start OK, it will shift into gear and the key can’t be removed unless you turn it off (I figured that pin might lock the key in).
So can anyone tell me what that little solenoid thing does? Something for an Auto? Something else entirely?
Also that locking PIN? Anything important I haven’t found out yet?
I might look into finding another newer variant and throwing that in which should be much much quicker now that I know how it all goes together. Anyone know where I might find another cheap one?
Part:
Solendoid?
Extra Pins:
