I have a 2019 AW Polo 1.0TSI 85kw with a misfire on cylinder 1 .... have a coilpack ready to go on, but which 1 is cylinder 1?
Which is Cylinder 1?
Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ... -
Usually count from the left, where the pulley is.
Some good tech files to download via the links below for this 1.0TSI 3 cylinder engine if you don't have them already.
Also refer to the image below (taken from the 2nd link on page 108 ) if thats of any help.
Spark-ignition three-cylinder engine 1.0l TSI 85 kW series EA211 (eng.) Design and principle of operation. Self-study program 111 Skoda - SKODA Karoq - BRISKODA
Скачивание файла -tsi-engine-1-0-chzd-chzb-chzc-dkrf-dkrc-dkld-chzj-dkra-dsha-repair-manual-eng.pdf
Thanks, I'll start there (on the left) replace and scan, and repeat if necessary on the other side if the error persists.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
So, some background on this misfire.
Have a friend's Polo 85TSI with a misfire. Mechanic told friend its the coilpack. Friend was quoted $900 + labour to replace 3 coilpacks.
I though the price was a bit rich and had 3 spare coilpacks (slightly older revision but still working) so could help friend out.
VCDS scan says its Cylinder 1.
Replaced the coilpack on cyl 1. Still a misfire.
Repeat on 2 and 3, still a misfire.
Replace all 3, still a misfire.
Pulled the 3 sparkplugs out, all very worn and old (probably never been replaced), though the 1 from cyl 1 was slight worse than the other 2.
Bought 3 new sparkplugs.
Fitted the 3 new plugs and refitted the original coilpacks. No misfire ....
Mechanic was doing a dodgy on my friend ...
Bottom line, unless you do it yourself, pick your mechanic carefully, and do not use a generic mechanic (such as my friend did).Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
Wow that's crazy, and $900 seems worse than the dealer would be, a set of R8 coilpacks maybe?
I saw a video recently when the car was a write-off because a mechanic said it needed an engine, it turns out it only had low compression because of a broken valve spring, fixed on the car without the head off.MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
Far out how annoyed would you be if you had paid $900 for 3x new spark plugs.........even if they are iridium they are $20 each or so?
Humble mechanic? Working on that neglected Mk7 GTI?Originally posted by MIG View PostI saw a video recently when the car was a write-off because a mechanic said it needed an engine, it turns out it only had low compression because of a broken valve spring, fixed on the car without the head off.
Bingo, that's the one!, good channel.Originally posted by Lucas_R View PostHumble mechanic? Working on that neglected Mk7 GTI?MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
$57 from VW each. Saw some online for ~$35-40, but that needed delivery of up to 2 weeks, needed them todayOriginally posted by Lucas_R View PostFar out how annoyed would you be if you had paid $900 for 3x new spark plugs.........even if they are iridium they are $20 each or so?
, so all up $160 for 3 new plugs.
From the looks of it, it needs an oil change urgently too, so will be doing that this weekend. I hate it when cars are neglected by their owners .... friends or not.Last edited by Sharkie; 21-02-2024, 03:23 PM.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
VW wants $140 per coilpack, so $420 plus labour of perhaps an hour, say $500 all up. For once the stealer is cheaper ....Originally posted by MIG View Post
I saw a video recently when the car was a write-off because a mechanic said it needed an engine, it turns out it only had low compression because of a broken valve spring, fixed on the car without the head off.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
