Most of us have some sort of bracing already... As it stands, I have had my car for 3.5 years and 95k km. As far as suspension goes I have a front strut brace, rear sway bar, and Weitec lowered springs... My shocks are on their way out (rear shocks are weeping), so in the process of looking for new spring, I realized how cheap coiloves could be, so I went with them... I personally feel that other than a rear strut tower brace, under body bracing is a bit of a load of wank... If you are going to dedicate your car to the track, fair enough, but....it's your money to spend, so it's up to the person buying it to decide if they want or need it...
1 of 2
2 of 2
Best coilovers for application
The UNIbrace that I listed for EOI is not the underbody one - it's the one to stiffen the rear between the towers. Unlike every other rear brace that I've seen, it works mainly in tension rather than compression (most only add a single sided tension brace as an afterthought if at all)
The underbody brace bit was an enquiry passed on by the UNIbrace people - I don't intend to get one (unless I decide to build a race car)
Lower, stiffer springs with standard shocks? That's a recipe for poor performance on anything other than perfectly smooth roads.Last edited by kaanage; 16-06-2011, 08:30 PM.Resident grumpy old fart
Originally posted by kaanage View PostLower, stiffer springs with standard shocks? That's a recipe for poor performance on anything other than perfectly smooth roads (and a wank)."If can't get behind your troops, feel free to stand in front of them..."
Originally posted by Blitzen View Postcan't be arsed getting one, modifying one to fit, then getting it properly engineered once installed...
and I did remove the "wank" reference after thinking about things but you must have started your reply before I edited that outLast edited by kaanage; 16-06-2011, 09:05 PM.Resident grumpy old fart
I've been running Eibach springs on standard shocks since 80,000 odd kms (now roughly 140,000) with no problems too
got FK's on the way though.06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
That your standard dampers are "OK" with the lowering springs doesn't make them a well engineered package. Apart from more body roll and less pose value, the standard springs work better when using the standard dampers.Resident grumpy old fart
Yeah I Know... But it just sits so high. Problem solved when I get the FKs06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
Unlike every other rear brace that I've seen, it works mainly in tension rather than compression (most only add a single sided tension brace as an afterthought if at all).
I'm thinking of knocking up a four point crossbrace and fixing it to similar points as a unibrace.
Would this have a similar effect?
I haven't had a chance to look at the rear towers, but another idea I have is to fab a simple tubular brace between the two towers with quick release fittings (ala bike wheels)
Would this have any positive effects, or turn out to be more of a 'wank' factor?
Originally posted by kaanage View PostThe whole point is if we can get them made to suit the 9N3, then there is no modifying or engineering (whatever you mean by that)"If can't get behind your troops, feel free to stand in front of them..."
Originally posted by spraycanmansam View PostCan you please explain this a little further?
I've been thinking along the lines of using adjustable steel cabling (ala yacht mast rigging) for the cross tensioning along with a beam across the 2 upper mounts to take the compression load to make a lighter and cheaper version of the UNIbrace but it would be nowhere near as pretty.
Originally posted by Blitzen View PostAhh, ok then... I misunderstood what was being said in the UNI brace thread... I thought you were getting Mk4 ones in...
Plus I think if someone has already bought good lowering springs and has failing dampers, then they should just buy good aftermarket dampers to suit the springs rather than throw the whole lot out with a set of coilovers (unless the height adjustment was the overriding requirement).Last edited by kaanage; 19-06-2011, 01:19 PM.Resident grumpy old fart
Originally posted by kaanage View PostI'd love to meet more people at events as misunderstanding posts drives me spare (I do it all too often). Eg I think we both agree that good coilovers or cup kits are superior to just lowering springs.Plus I think if someone has already bought good lowering springs and has failing dampers, then they should just buy good aftermarket dampers to suit the springs rather than throw the whole lot out with a set of coilovers (unless the height adjustment was the overriding requirement)."If can't get behind your troops, feel free to stand in front of them..."
If you got the coilovers at a comparable price to replacement dampers, that's fair enough. Surprises me, though.Resident grumpy old fart
The boot space of the Polo is quite shallow, I'm not sold on how much it's going to affect the Polo... I guess it's a case of wait and see, there is Merritt in the bracing, but if it makes as much difference as other handling mods will have to wait for testing.
I think it's a great idea, but the cash is too much for my perception of the benefit (all I have to go on for now).
