Seat Air Intake Installation Instructions.
  • Seat Air Intake Installation Instructions.
    Seat Air Intake Fitting Instructions
    Tools Needed
    1. Philips Screw Driver (preferably a magnetic tip one)
    2. No. 20 Torx Bit.( you should be able to use a allen key but im not recommending it)
    3. Torch (I needed one)
    4. Stanley Knife
    Parts Needed.
    1. Seat Air Intake Hose
    2. Seat Air Intake Trumpet.
    Time - 15min
    Here is a picture of the original One.
    And a few Pictures of the differences between the standard one and the Seat one.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    Now here is a step by step guide.
    1. Near the Air Box you will see a screw. (see picture below) Remove the screw. Making sure you don’t drop it.
    2. Now you will see a join. (below pic). Pull the Hose section out of the join and then pull it away from the airbox.
    3. Now there are 4 tabs on trumpet 2 one the top and one either side. (Pic Below) Push the Tabs in and pull the standard trumpet out.
    Have a Look
    CUSTOM CODE
    Phase 2
      THE NEXT 2 ARE OPTIONAL. It has been pointed out that the flap maybe there to deflect stones down. But in my opinion they cant get very far anyway. And the Grill should stop most. SO these steps are your persaonal Choice. (PM me your thoughts please.)
      4. Now you will see the part that the trumpet came out of. It is attached to the front of the car with 2 torx bits. (below pic) Undo the screws and take induction funnel out.
      5. Look down the induction funnel and you will see a flap that is blocking the flow of air. (Pic below) Cut it out with a Stanley knife or something similar.
      And it will look like this.
      Have a Look
      CUSTOM CODE
      Phase 2
        6. Time to put it back together. Its pretty straight forward. Start with the induction funnel. Then the Seat Intake Hose. Put it in first. This is a tight fit but will go in no worries. Then put the Trumpet on the Hose and pop it into the Induction Funnel. And it will look just like the original again.
        Please try to keep this thread free of chit chat as this is only an Instruction Guide. If something doesnt make sense please PM me and i will look into it.
        Have a Look
        CUSTOM CODE
        Phase 2
          Shaneth well done on the writeup! very easy to follow - Now tell us how she goes!
          Would it be recommended to sand off the platic bit after cutting it out with a stanley knife?
            Ryan to be honest i dont want to say much as far as performance gains as i dont want to lead anyone astray. I will say this is only part of my intake upgrade. I will be doing a bmc goup buy prolly in a month so that everyon can get the funds. Then i want the TIP fro forge which i will probably do a group buy as well if i can get a good enough price from england.
            See the thing is with small mods like this that you can imagine huge gains. (something like a placebo effect) It is colder atm so it will affect it as well but i can honestly say seat of my pants it does feel stronger but like i said i would need VAg-com to justify that with some real time figures if oyu know what i mean.
            Have a Look
            CUSTOM CODE
            Phase 2
              Good write up Shaneth keep up the good work mate.
              It looks good as it doesn't seem different to the stock one.
                Thanks mate, Thats exactly why i did it and not just put a piece if pipe in there. I want me ebay as stock looking as i can.
                Have a Look
                CUSTOM CODE
                Phase 2
                  Awesome write up mate, you are an inspiration to us all.
                  The old looks very restrictive in place of the new.
                    thanks loon, Yeah its at least half the size of the Seat one if not a little smaller. and when you remove the flap i recon air will get force up into the airbox with ease.
                    Have a Look
                    CUSTOM CODE
                    Phase 2
                      Does the old one have this flap also? Just wondering if I leave the flap there will the new bits make such a difference....
                        The flap is part of what i called the induction funnel. Its not part of what you are replacing but the trumpet sits in it. Not sure how not removing it will affect. But as you can see in the pic it is fairly restrictive. I guess in the end its up to you. Id say hhave a look when you take it all apart, and see what you think. I cant see how anything can get into the airbox if you do remove the flap but thats my opinion.
                        Have a Look
                        CUSTOM CODE
                        Phase 2
                          Good work shaneth. Manages to look stock and seamless so I reckon most VW service centres probably wouldn't notice (or care) in most cases. If you check out some of other hoses in the bay, there's seat hoses already in there!
                          The air intake in the Polo GTI is it's weakest link. Not much point in installing a larger pipe if the front intake flap is blocking most of the air to begin with. That should go or be opend up completely. Also, it's well worth changing the paper air filter with a BMC one (much higher flow). Then you have freed up flow in three critical areas. Most drivers would then notice that their cars won't die off at 5-5000 rpm anymore, that's bc the turbo is getting the extra air it badly needs.
                            Where do I get?
                            Hi Guys
                            The SEAT air intake sounds like a good thing - can anyone advise where you get it from?
                              Originally posted by jayzee75 View Post
                              Hi Guys
                              I 2nd that, I'm picking up my new GTI next week and would like to know where to source one of these SEAT air intakes in Melbourne.
                              Sell me your Polo GTI 9n3 and/or go fast bits.... please
